    Xc sources controller
    GamePad/GPIO/USB encoder
    sources
    • Rencri
      Rencri last edited by
      Ciao ragazzi, ho appena costruito un cabinato arcade ma quando monto due player e provo ad usarli vanno in conflitto. Uno dei due si inverte di comandi tipo in alto diventa in basso ecc.. soluzioni?
        Hello
        Check your wiring
        You must wire your controller player 1 and player 2 in a similar way
        You only need to configure player 1 in emulationstation
        you need to use recalbox 4.1
        https://archive.recalbox.com/updates/v1.0/unstable/
        Rencri 1 Reply Last reply Reply Quote 0
        • Rencri
          Rencri @acris last edited by
          @acris ok, you can call me? 3493467567
            No, i cant call you.
            • Rencri
              @acris i used xc sources controller, the wire is the same for 2 controller but i cant use the second because it switches the control
