    USB External HDD disconnecting
    usb external hdd disconnecting
    • reiserfs
      reiserfs last edited by acris
      I have an external HDD Samsung S2 Portable with 500gb and a Raspberry pi3 with two OS, Raspian and Recalbox.
      In Raspian the HDD is mounted without problems, but in Recalbox he wont mount and if im inside kodi, kodi crash, in the logs i saw that the HDD keep disconnecting and connectiong again, he one time mount but it disconnect after a few seconds.
      I have changed the config.txt and put max_usb_current=1 options, but without success.
      The Log:
      *May 31 01:25:16 RECALBOX user.info kernel: [  132.068588] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
      May 31 01:25:17 RECALBOX user.info kernel: [  132.169644] usb 1-1.2: New USB device found, idVendor=04e8, idProduct=1f05
      May 31 01:25:17 RECALBOX user.info kernel: [  132.169670] usb 1-1.2: New USB device strings: Mfr=1, Product=11, SerialNumber=3
      May 31 01:25:17 RECALBOX user.info kernel: [  132.169793] usb 1-1.2: Product: Samsung S2 Portable
      May 31 01:25:17 RECALBOX user.info kernel: [  132.169805] usb 1-1.2: Manufacturer: JMicron
      May 31 01:25:17 RECALBOX user.info kernel: [  132.169818] usb 1-1.2: SerialNumber: 0000002CE123F
      May 31 01:25:17 RECALBOX user.err kernel: [  132.425993] usb 1-1.2: can't set config #1, error -71
      May 31 01:25:17 RECALBOX user.info kernel: [  132.428099] usb 1-1.2: USB disconnect, device number 7
      May 31 01:25:20 RECALBOX user.info kernel: [  135.648618] usb 1-1.2: new high-speed USB device number 8 using dwc_otg
      May 31 01:25:21 RECALBOX user.err kernel: [  136.348584] usb 1-1.2: device not accepting address 8, error -71
      May 31 01:25:23 RECALBOX user.info kernel: [  138.978544] usb 1-1.2: new high-speed USB device number 10 using dwc_otg
      May 31 01:25:23 RECALBOX user.info kernel: [  139.079419] usb 1-1.2: New USB device found, idVendor=04e8, idProduct=1f05
      May 31 01:25:23 RECALBOX user.info kernel: [  139.079443] usb 1-1.2: New USB device strings: Mfr=1, Product=11, SerialNumber=3
      May 31 01:25:23 RECALBOX user.info kernel: [  139.079457] usb 1-1.2: Product: Samsung S2 Portable
      May 31 01:25:23 RECALBOX user.info kernel: [  139.079470] usb 1-1.2: Manufacturer: JMicron
      May 31 01:25:23 RECALBOX user.info kernel: [  139.079482] usb 1-1.2: SerialNumber: 0000002CE123F
      May 31 01:25:23 RECALBOX user.info kernel: [  139.080721] usb-storage 1-1.2:1.0: USB Mass Storage device detected
      May 31 01:25:23 RECALBOX user.info kernel: [  139.081245] scsi host1: usb-storage 1-1.2:1.0
      May 31 01:25:24 RECALBOX user.info kernel: [  139.512827] usb 1-1.2: USB disconnect, device number 10
      May 31 01:25:27 RECALBOX user.info kernel: [  142.568603] usb 1-1.2: new high-speed USB device number 11 using dwc_otg
      May 31 01:25:27 RECALBOX user.info kernel: [  142.669666] usb 1-1.2: New USB device found, idVendor=04e8, idProduct=1f05
      May 31 01:25:27 RECALBOX user.info kernel: [  142.669704] usb 1-1.2: New USB device strings: Mfr=1, Product=11, SerialNumber=3
      May 31 01:25:27 RECALBOX user.info kernel: [  142.669717] usb 1-1.2: Product: Samsung S2 Portable
      May 31 01:25:27 RECALBOX user.info kernel: [  142.669730] usb 1-1.2: Manufacturer: JMicron
      May 31 01:25:27 RECALBOX user.info kernel: [  142.669742] usb 1-1.2: SerialNumber: 0000002CE123F
      May 31 01:25:27 RECALBOX user.info kernel: [  142.671276] usb-storage 1-1.2:1.0: USB Mass Storage device detected
      May 31 01:25:27 RECALBOX user.info kernel: [  142.674652] scsi host2: usb-storage 1-1.2:1.0
      May 31 01:25:27 RECALBOX user.info kernel: [  143.097211] usb 1-1.2: USB disconnect, device number 11
      May 31 01:25:31 RECALBOX user.info kernel: [  146.148641] usb 1-1.2: new high-speed USB device number 12 using dwc_otg
      May 31 01:25:31 RECALBOX user.info kernel: [  146.249612] usb 1-1.2: New USB device found, idVendor=04e8, idProduct=1f05
      May 31 01:25:31 RECALBOX user.info kernel: [  146.249645] usb 1-1.2: New USB device strings: Mfr=1, Product=11, SerialNumber=3
      May 31 01:25:31 RECALBOX user.info kernel: [  146.249659] usb 1-1.2: Product: Samsung S2 Portable
      May 31 01:25:31 RECALBOX user.info kernel: [  146.249672] usb 1-1.2: Manufacturer: JMicron
      May 31 01:25:31 RECALBOX user.info kernel: [  146.249684] usb 1-1.2: SerialNumber: 0000002CE123F
      May 31 01:25:31 RECALBOX user.info kernel: [  146.251150] usb-storage 1-1.2:1.0: USB Mass Storage device detected
      May 31 01:25:31 RECALBOX user.info kernel: [  146.252752] scsi host3: usb-storage 1-1.2:1.0
      May 31 01:25:31 RECALBOX user.info kernel: [  146.681843] usb 1-1.2: USB disconnect, device number 12
      May 31 01:25:43 RECALBOX user.info kernel: [  158.698533] usb 1-1.2: new high-speed USB device number 13 using dwc_otg
      May 31 01:25:43 RECALBOX user.info kernel: [  158.799275] usb 1-1.2: New USB device found, idVendor=04e8, idProduct=1f05
      May 31 01:25:43 RECALBOX user.info kernel: [  158.799300] usb 1-1.2: New USB device strings: Mfr=1, Product=11, SerialNumber=3
      May 31 01:25:43 RECALBOX user.info kernel: [  158.799313] usb 1-1.2: Product: Samsung S2 Portable
      May 31 01:25:43 RECALBOX user.info kernel: [  158.799326] usb 1-1.2: Manufacturer: JMicron
      May 31 01:25:43 RECALBOX user.info kernel: [  158.799339] usb 1-1.2: SerialNumber: 0000002CE123F
      May 31 01:25:43 RECALBOX user.info kernel: [  158.800470] usb-storage 1-1.2:1.0: USB Mass Storage device detected
      May 31 01:25:43 RECALBOX user.info kernel: [  158.803505] scsi host4: usb-storage 1-1.2:1.0
      May 31 01:25:44 RECALBOX user.info kernel: [  159.227248] usb 1-1.2: USB disconnect, device number 13
      May 31 01:25:47 RECALBOX user.info kernel: [  162.278530] usb 1-1.2: new high-speed USB device number 14 using dwc_otg
      May 31 01:25:47 RECALBOX user.info kernel: [  162.379290] usb 1-1.2: New USB device found, idVendor=04e8, idProduct=1f05
      May 31 01:25:47 RECALBOX user.info kernel: [  162.379313] usb 1-1.2: New USB device strings: Mfr=1, Product=11, SerialNumber=3
      May 31 01:25:47 RECALBOX user.info kernel: [  162.379327] usb 1-1.2: Product: Samsung S2 Portable
      May 31 01:25:47 RECALBOX user.info kernel: [  162.379340] usb 1-1.2: Manufacturer: JMicron
      May 31 01:25:47 RECALBOX user.info kernel: [  162.379353] usb 1-1.2: SerialNumber: 0000002CE123F
      May 31 01:25:47 RECALBOX user.info kernel: [  162.380613] usb-storage 1-1.2:1.0: USB Mass Storage device detected
      May 31 01:25:47 RECALBOX user.info kernel: [  162.382251] scsi host5: usb-storage 1-1.2:1.0
      May 31 01:25:48 RECALBOX user.notice kernel: [  163.420731] scsi 5:0:0:0: Direct-Access     Samsung  S2 Portable           PQ: 0 ANSI: 2 CCS
      May 31 01:25:48 RECALBOX user.notice kernel: [  163.422423] sd 5:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
      May 31 01:25:48 RECALBOX user.notice kernel: [  163.422857] sd 5:0:0:0: [sdb] Write Protect is off
      May 31 01:25:48 RECALBOX user.debug kernel: [  163.422880] sd 5:0:0:0: [sdb] Mode Sense: 28 00 00 00
      May 31 01:25:48 RECALBOX user.err kernel: [  163.423224] sd 5:0:0:0: [sdb] No Caching mode page found
      May 31 01:25:48 RECALBOX user.err kernel: [  163.423242] sd 5:0:0:0: [sdb] Assuming drive cache: write through
      May 31 01:25:48 RECALBOX user.info kernel: [  163.708996] usb 1-1.2: USB disconnect, device number 14
      May 31 01:25:48 RECALBOX user.info kernel: [  163.728606] sd 5:0:0:0: [sdb] UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
      May 31 01:25:48 RECALBOX user.info kernel: [  163.728638] sd 5:0:0:0: [sdb] CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
      May 31 01:25:48 RECALBOX user.err kernel: [  163.728653] blk_update_request: I/O error, dev sdb, sector 0
      May 31 01:25:48 RECALBOX user.err kernel: [  163.728667] Buffer I/O error on dev sdb, logical block 0, async page read
      May 31 01:25:48 RECALBOX user.info kernel: [  163.728961]  sdb: unable to read partition table
      May 31 01:25:48 RECALBOX user.info kernel: [  163.729722] sd 5:0:0:0: [sdb] Read Capacity(10) failed: Result: hostbyte=0x01 driverbyte=0x00
      May 31 01:25:48 RECALBOX user.notice kernel: [  163.729740] sd 5:0:0:0: [sdb] Sense not available.
      May 31 01:25:48 RECALBOX user.notice kernel: [  163.729860] sd 5:0:0:0: [sdb] Attached SCSI disk
      May 31 01:25:48 RECALBOX user.info usbmount[803]: /dev/sdb does not contain a filesystem or disklabel
      May 31 01:25:48 RECALBOX daemon.err kernel: [  163.832876] udevd[798]: inotify_add_watch(6, /dev/sdb, 10) failed: No such file or directory*
        is it self powered or relies on the USB power supply ?
