    Power button troubles when the Pi is OFF...
    button troubles off
    • cotedeporc
      cotedeporc last edited by
      Hello,
      I have install a Power and Reset button following theses guides:
      https://github.com/recalbox/recalbox-os/wiki/Ajouter-un-bouton-on-off-a-votre-recalbox-(FR)
      After that, I updated the @supernature2k script to Short/Long press version:
      https://forum.recalbox.com/topic/6996/bouton-gpio-quitter-émulateur
      It works great when the Pi is On, BUT...
      • When the Pi is Off (or in stand-by) it still only needs a short press to start it
      • Sometimes, the Pi start by himself with no reason
      I suspect some interferences in the electric system. For this case, does an EMI filter is mandatory in front of the Pi alimentation?
      @supernature2k
      There is a place where I can see the logs of your script?
      Thank you in advance guys!
      Thème FoolScreen / Squared
      supernature2k 1 Reply Last reply Reply Quote 0
      • supernature2k
        supernature2k @cotedeporc last edited by
        @cotedeporc Hi!
        The script is not logging anything and to be honest the Pi starting by button press after shutdown is a "side effect", there is nothing in the script that tells the pi to do so.
        So the wake up will always be a short press meaning of course that a small short circuit could also trigger the wake.
        cotedeporc 1 Reply Last reply Reply Quote 0
        • cotedeporc
          cotedeporc @supernature2k last edited by
          @supernature2k
          Thanks for the answer!
          Do you face the same problem with all your RecalBoxes?
          I will try with an EFI filter in front of the Pi. I expect to be interference-proof.... 🐵
          I will post the results in this thread.
          • supernature2k
            @cotedeporc nope, I had sometimes the "shutdown" behavior before adding timer in the script (especially when pluging USB devices) but never experienced the power on 🙂
            101.0k
