    Quick question, how to select 2nd player using keyboard?
    GamePad/GPIO/USB encoder
    quick select 2nd player keyboard
    • mikejkelley
      mikejkelley last edited by
      My controls are only set up for 1 player but I'd like to select a 2nd player using a USB wireless keyboard. This is so that I can practice my combos.
      • nickdj
        nickdj last edited by
        If you wish to use a keyboard and joypad simply select the second player as the joypad and leave first player as default.  This should work.
        RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
        • mikejkelley
          Thanks! 🙂
          • mateus-arantes
            mateus-arantes last edited by
            Can I configure s second player on keyboard? Because I using a I-PAC...
            • abioneperhobby
              abioneperhobby last edited by
              i tried but it doesn't works for me on 4 beta 2 on rasp3 . even both keyboard and usb controller are configured and working and i set "default" for first player or second, usb and keyboard maps the same player (the first). should i open a new thread? thanks
