    My Sega Recalbox
    Your recalbox
    sega recalbox
    3678
    • davros1969
      davros1969 Banned last edited by
      Hi all, I have just finished constructing my pi3 recalbox fitted inside a Sega USB hub - as per the many tutorials on the web - it's neat and recalbox looks good on it. What a great little os. I have tried retropie, lakka and running the emulators on windows. So far for ease of use - that the Xbox controller is plug and play - recalbox is top of the tree. All I need to do now is try all the emulators and see how they compare! Great job done by the community!
      I take it if I ask a question then I should start a thread if I can't find a solution already posted on the forum?
        Substring @davros1969 last edited by
        @davros1969 said in My Sega Recalbox:
        Yeah, that's the common way of running through difficulties 😉
        But we'd rather have pics of your segalbox/regalbox/secalbox (name it the way you want lol)
        davros1969 1 Reply Last reply Reply Quote 0
        • davros1969
          davros1969 Banned @Substring last edited by
          @Substring aha pictures. No worries when I get round to it. The wife calls it the 'stupid plastic toy'
          Substring 1 Reply Last reply Reply Quote 1
            @davros1969 A girl shall not speak of things she doesn't know would Jaqen H'ghar say hahaha 😄
            • davros1969
                @davros1969 so you cut through the cart slot ?
                • davros1969
                  @Substring wonders of a dremel. Allows a bit of heat to float away from the pi. I'll monitor the temp as I go and will fit a mini fan if needed. Good thing is it still functions as a 4 port hub. Although I forget how many times I dismantled it to shave some more plastic off of the cable holes I had cut
                    @davros1969 You can ask @supernature2k how he managed to use the buttons on/off and reset and integrate them inside recalbox 🙂
