    Easy get arcade controls/ joystick Issues
    GamePad/GPIO/USB encoder
    easy get joystick no wor gamepad issue no connection help
    • Blade1
      Blade1 last edited by Blade1
      Hi,
      New to the forum. Haven't seen another thread that has this issue. I have a RP3 in a cabinet connected to some easy get brand sticks and buttons/ 32gb micro sd/ small speakers and the latest version of recalbox.
      Here's a link:
      https://www.amazon.com/Easyget-Arcade-Encoder-Joystick-Fighting/dp/B00XHRIKLE
      The problem is having is the RP isn't recognizing them. I don't have any response when I try the buttons or joysticks. I have power to buttons cause when I push them they light up. What could the issue be?
      Does anyone here run their games strictly by traditional joystick and buttons? Can running mame and the other emulators be easy by using cabinet controls?
      I was thinking of just trashing the easy get joystick and button thinking an iPac would be easier?
      Thanks a ton
        Substring @Blade1 last edited by
        @Blade1 Hi,
        You should connect through SSH to your pi and check with evtest if the board is seen. Which recalbox version are you running ? If you're on recalbox 4.0, please read https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
