    Out of range display
    Themes & Interface
    range display
    3670
    • Xife Li
      Xife Li last edited by
      I tried to narrow the display range, but did not succeed
      /boot/config.txt
      disable_overscan=0
      overscan_left=119
      overscan_right=60
      overscan_top=21
      overscan_bottom=7
      framebuffer_width=320
      framebuffer_height=240
      2_1494370138258_17952811_10155085755220340_7613865091940522501_n.jpg 1_1494370138258_17861835_10155085755285340_744320401669924431_n.jpg 0_1494370138257_17799079_10155085755275340_2793346548633840933_n.jpg
      May I fix this question?
        Substring @Xife Li last edited by
        @Xife-Li are you running on composite ?
        Xife Li 1 Reply Last reply Reply Quote 0
        • Xife Li
          Xife Li @Substring last edited by
          @Substring yes
            faced the problem myself too, looks i couldn't solve it either. Should dig some more one day or another
            • Xife Li
              @Substring oh~ thx
                ajoutez cette ligne dans votre config.txt :
                overscan_scale=1
                • Xife Li
                  Xife Li @rockaddicted last edited by
                  @rockaddicted said in Out of range display:
                  overscan_scale=1
                  Successfully solve the problem, thank you
                    rockaddicted @Xife Li last edited by
                    @Xife-Li you are welcome
