    Recalbox Menü immer nur in 640x480
    Recalbox
    recalbox menü immer nur 640x480
    3561
    • boergim
      boergim last edited by rockaddicted
      Moin zusammen,
      Das Recalbox Menü ist bei mir immer in der Auflösung 640x480.
      Spiele werden aber immer in der richtigen Auflösung gestartet.
      Der Monitor unterstützt eine max Auflösung von 1600x1200.
      Hier meine Configs.
      config.txt:
      # uncomment if you get no picture on HDMI for a default "safe" mode
      hdmi_safe=1
      disable_overscan=1
      # uncomment to force a specific HDMI mode (this will force VGA)
      hdmi_group=2
      hdmi_mode=51
      # comment to get jack audio
      #hdmi_drive=1
      config_hdmi_boost=4
      # force hdmi while the tv can take time before sending the signal on the hdmi output
      #hdmi_force_hotplug=1
      # uncomment for composite PAL
      #sdtv_mode=2
      # uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      # uncomment if you don't want the rainbow at startup
      disable_splash=1
      # Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      avoid_safe_mode=1
      kernel=zImage
      # NOOBS Auto-generated Settings:
      hdmi_ignore_edid=0xa5000080
      config_hdmi_boost=4
      hdmi_group=2
      hdmi_mode=4
      disable_overscan=0
      overscan_left=24
      overscan_right=24
      overscan_top=24
      overscan_bottom=24
      recalbox.conf:
      # System Variable
      system.manager.enabled=1
      ## Recalbox API (REST)
      system.api.enabled=0
      ## EmulationStation menu style
      ## default -> default all options menu
      ## none -> no menu except the game search menu
      ## bartop -> less menu, only needed for bartops
      system.es.menu=default
      ## Emulator special keys
      kodi.enabled=0
      ## Start kodi at launch (0,1)
      kodi.atstartup=0
      ##kodi.xbutton=1
      ;kodi.network.waittime=10
      ## Set system hostname
      system.hostname=RECALBOX
      ## Activate wifi (0,1)
      wifi.enabled=1
      ## Wifi SSID (string)
      wifi.ssid=****
      ## Wifi KEY (string)
      wifi.key=****
      ## Samba share
      system.samba.enabled=1
      ### Virtual Gamepads
      ### SSH
      system.ssh.enabled=1
      audio.device=jack
      ## Set system volume (0..100)
      audio.volume=100
      audio.bgmusic=1
      controllers.ps3.enabled=1
      ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
      controllers.xboxdrv.enabled=0
      ## GPIO Controllers
      controllers.gpio.enabled=0
      controllers.gpio.args=map=1,2
      ## DB9 Controllers
      controllers.db9.enabled=0
      ## db9 arguments
      controllers.db9.args=map=1
      ## Gamecon controllers
      controllers.gamecon.enabled=0
      ## gamecon_args
      controllers.xarcade.enabled=1
      system.language=de_DE
      ;system.kblayout=us
      ## Set you local time
      ;system.timezone=Europe/Paris
      updates.enabled=0
      # default : stable ; set to beta to get the next version currently being tested. set to unstable at your own risk to get the development version.
      updates.type=stable
      ## (string)
      global.videomode=DMT 51 HDMI
      ## Shader set
      ## (none, retro, scanlines)
      global.shaderset=retro
      global.integerscale=1
      global.shaders=
      global.ratio=4/3
      global.smooth=1
      global.rewind=1
      global.autosave=0
      global.retroachievements=0
      global.inputdriver=auto
      ## Here is the snes example
      ;snes.videomode=DMT 51 HDMI
      snes.core=snes9x_next
      ;snes.ratio=4/3
      ;snes.smooth=0
      ;snes.rewind=1
      ;snes.autosave=0
      ;snes.emulator=libretro
      ;snes.integerscale=0
      ## Default cores for RPi3
      gba.core=mgba
      mame.core=default
      nes.core=fceunext
      ## NeoGeo emulator
      neogeo.emulator=libretro
      ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
      neogeo.core=fba
      n64.videomode=DMT 4 HDMI
      # n64.videomode=default
      mame.emulator=libretro
      fba_libretro.emulator=default
      mastersystem.emulator=default
      mastersystem.ratio=4/3
      megadrive.emulator=libretro
      megadrive.core=genesisplusgx
      Ich hab schon einiges ausprobiert und leider keine Lösung gefunden, hoffe Ihr könnt mir helfen.
      Danke schonmal ;).
      gruß BoergiM
        Substring @boergim last edited by
        @boergim Hi !
        As my german is too old to answer correctly in german, I'll answer in English !
        To avoid repeating the doc, I strongly encourage you to read https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        Now, you're stuck because of hdmi_safe=1 in your config.txt 😉
        boergim 1 Reply Last reply Reply Quote 0
        • boergim
          boergim @Substring last edited by
          @Substring Hi,
          I have uncommanded the config hdmi_safe=1 but the resolution is still the same.
            @boergim you should comment it 😉
            • boergim
              @Substring
              I'm too stupid.
              Thats my config.txt in this moment and the resolution is 640x480:
              #hdmi_safe=1
              disable_overscan=1
              hdmi_group=2
              hdmi_mode=51
              #hdmi_drive=2
              config_hdmi_boost=4
              #sdtv_mode=2
              #dtoverlay=lirc-rpi
              boot_delay=3
              disable_splash=1
              # Overclock
              gpu_mem_256=128
              gpu_mem_512=256
              gpu_mem_1024=512
              avoid_safe_mode=1
              kernel=zImage
              config_hdmi_boost=4
              hdmi_group=2
              hdmi_mode=4
              disable_overscan=0
              overscan_left=24
              overscan_right=24
              overscan_top=24
              overscan_bottom=24
                @boergim I'm surprised as it doesn't really look like the default recalbox config.txt
                What if you comment hdmi_modeand hdmi_group ?
                • boergim
                  boergim @Substring last edited by boergim
                  @Substring
                  I have found the Problem.
                  The Problem was the Auto-generated Settings: vom Noobs.
                    @boergim the noobs part is surprinsingly very big compared to usual, most of times i completely delete it. But now i don't even have noobs anymore on my recalbox SDs
                    Glad you made it 🙂
                    100.9k
