    Ghosts'n Goblins - MAME ROM
    Emulator Arcade/PC/Console
    ghostsn goblins mame rom
    8738
    • duskel
      duskel last edited by
      Hi guys,
      No version of Ghosts'n Goblins (MAME 0.78 ROM SET) is working properly.
      Either I cannot include more credits during the game or the game does not start.
      Any idea?
      Recalbox 4.0.2.
      Thanks!
      Pepe 1 Reply Last reply Reply Quote 0
      • Pepe
        Pepe @duskel last edited by
        @duskel U don't have the correct Mame 0.78 gng.zip rom, game runs ok.
        • Neil_Hines
          Neil_Hines last edited by
          Hi @Pepe maybe you are correct because I have Mame and it is working perfectly.
          • duskel
            duskel last edited by duskel
            I tried from different sites (all of them mame 2003 rom set).
            Which site do you guys download your MAME2003 roms?
            Thank you!
            tikiandskull 1 Reply Last reply Reply Quote 0
            • tikiandskull
              tikiandskull @duskel last edited by tikiandskull
              @duskel got mine from your link and it work!
              (Remove your link it's not allowed)
              • duskel
                @tikiandskull that's crazy, on my side I get "error RAM NO GOOD 0002", I found a post (same error) saying to delete the cfg (\recalbox\share\roms\mame\mame2003\cfg), I did it, but it did not work too.
                tikiandskull Pepe 2 Replies Last reply Reply Quote 0
                • tikiandskull
                  @duskel don't know why!!! (Edit your post and remove your link)
                  • Pepe
                    @duskel What Mame core do u use to run the rom?
                    duskel 1 Reply Last reply Reply Quote 0
                    • duskel
                      duskel @Pepe last edited by
                      @Pepe I have updated recalbox to version 4.0.2, so I would say the version which comes on this version. I suppose mame 2003.
                      • tikiandskull
                        @duskel i use recalbox 4.1 unstable maybe that's why it works for me
                        • Pepe
                          Pepe @duskel last edited by Pepe
                          @duskel check it in your config, you're probably using a different core. In ES, press start to open menu, select game settings/advanced/mame, check emulator and core, u will see, some emulator and cores, to run with mame 0.78 both option at default or both emulator=libretro core=mame 0.78 both are the same thing. If it is configured in some other way then you are not running your roms with mame 0.78, change it.
                          @tikiandskull the correct 0.78 rom runs perfectly in 4.0, 4.01, 4.02 and 4.1. I have played same romfile in the 4 recalbox versions
                          tikiandskull 1 Reply Last reply Reply Quote 1
                          • tikiandskull
                            tikiandskull @Pepe last edited by
                            @Pepe I believe you, but I just tried with the 4.1 🙂
                            • duskel
                              @Pepe just checked it. Both were default, tried to move to libreto / mame 078. I did not work too.
                              • sulsifsen
                                sulsifsen last edited by
                                Hi
                                you can usethe japanese version of it called makaimura (makaimuc file name).
                                The title is in japanese but the experience is still there!!!
                                cheers
