    CABAL - ARCADE ROM
    Emulator Arcade/PC/Console
    cabal arcade rom
    4416
    • duskel
      duskel last edited by
      Hi guys,
      Facing a small issue with Cabal ROM.
      There are differents versions, but the only version which the button to roll works is the "Cabal (bootleg Of Joystick version, alternate sound hardware)", but sound is crap.
      Any idea?
      I tried versions to MAME 0.78 ROM SET.
      Thanks!
      Pepe 1 Reply Last reply Reply Quote 0
      • Pepe
        Pepe @duskel last edited by Pepe
        @duskel
        What does this mean for you?
        This alternate sound hardware is not properly emulated yet.
        cabalbl Mame driver status In http://www.gamesdatabase.org/mame-rom/cabalbl :
        <description>Cabal (bootleg of Joystick version, set 1, alternate sound hardware)</description>
        <driver status="imperfect" emulation="good" color="good" sound="imperfect" graphic="good" savestate="unsupported" palettesize="1024"/>
        Bugs:
        • Cabal uses MSM5205 chips instead of the custom ADPCM. Kold666 (ID 01550)
        • duskel
          @Pepe,
          In fact I also tried cabal.zip, but there is no roll up button. That's why I tried cabalbl.
          Thanks.
          • Pepe
            @duskel This is because the original game does not have roll movement, it's a hack of this bootleg version.
              Substring @Pepe last edited by
              @Pepe I'd rather refer to https://github.com/libretro/mame2003-libretro/blob/7b55725e744ac9702db092f996e2fca2276146b2/src/drivers/cabal.c#L718 😉
              Web based databases mostly rely on the latest MAME versions 'despite your site showed the evolution of hte driver through the versions ^^)
              • Pepe
                Pepe @Substring last edited by
                @Substring ok.
                • duskel
                  @Substring
                  What should I do with this source code?
                  Sorry, I am new on this Recalbox / ROMs world.
                  Thanks!
                    Substring @duskel last edited by
                    @duskel you have the real info about what the emulator knows about the rom : sound can't work properly (on mame 0.78).
