    How do i load more then 1 dreamcast game?
    more dreamcast
    • Tomsen
      Tomsen last edited by
      Hi,
      I have a Odroid XU4 running recalbox.
      When I'm trying to put more then 1 game up in my dreamcast rom folder it says, do you want to replace the .bin files?.
      That is because the game has 4 files that I have to put in the folder, the GDI file is only 1 kb. How can I put more games in the rom folder?
        Substring @Tomsen last edited by
        @Tomsen either rename bin files and do the same in the related cue file. Or drop each game in a subfolder
        • Tomsen
          Thank you very much!
          • Tornelf
            Tornelf last edited by Tornelf
            @Tomsen Hi,
            You can also try to get .cdi images instead of .gdi. They are most of the time lighter and in a unique file.
            Raspberry 4
            ODROID XU 4 avec ventilo bruyant
            Microsoft xbox 360 wireless pad
            Clavier Logitech k400
            RECALBOX 7.2
            Tomsen 1 Reply Last reply Reply Quote 0
            • Tomsen
              Tomsen @Tornelf last edited by
              @Tornelf ok, thanks. I will search for cdi files.
