    Solved MAME "R2 Menu" hotkey issue
    Emulator Arcade/PC/Console
    mame hotkey issue
    • Cheddar
      Cheddar last edited by
      Hey, so I was trying to fix my MAME resolution through "that one menu that appears when you press Tab or R2 in controller 1" and I accidentally set the Open Menu key to None.
      Now "that one menu that appears when you press Tab or R2 in controller 1" is no longer accessible. Does anyone know how to revert this? Maybe resetting some cfg file?
      Thanks!
      RetroDude78 1 Reply Last reply Reply Quote 0
      • Cheddar
        By the way: fixed the resolution issue using Overscan
          Hello @Cheddar
          delete /recalbox/roms/mame/mame2003/cfg/default.cfg and reboot
          • RetroDude78
            RetroDude78 @Cheddar last edited by
            Does anyone know how to do this in the current version of Recalbox? I seem to have done the same thing, but this file no longer appears to be the one to fix this issue! Thanks all!!
            • RetroDude78
              RetroDude78 @RetroDude78 last edited by
              Aha... I found it! In case anyone is looking like me, the file is now here:
              /saves/mame/mame2003/cfg/default.cfg
