    Recalbox unstable and Kodi problems
    MediaCenter & Dualboot
    kodi addon live stream problem
    5078
    • Tony32
      Tony32 last edited by
      Hello 🙂
      I am running latest unstable for RPI 3. Also had the same issue with stable. I use USB flash drives as storage. Using built in wifi with 100/100mbit internet.
      Recalbox overall is working flawlessly, for which I am thankful for. I just have some problems with addons for kodi. Installing addons fails on installation and complains it cant install dependencies. This is a pain, but I can get around it.
      The real problem is live addons don't work, or just work sometimes.
      Addons I am having problems with is TV3 Play and Twitch, from official repo. The thing is, it works perfectly on my laptop running Kodi 16, not on the pi. Sometimes it says "opening stream" and nothing happening, or it says one or more items failed to Play/load.
      Just two Times have Twitch worked(right arter Kodi restart) and if i switched streamer it broke again. Tv3 Play never worked event once. Can anyone of you confirm if its just me it for everyone?
      Thanks, and sorry for the English, phone autocorrect.
      azvarel 1 Reply Last reply Reply Quote 0
      • azvarel
        azvarel @Tony32 last edited by
        @Tony32
        You may have corrupted a file during the installation, already tested with another flashdrive or tried to rename the recalbox folder of your flashdrive to another name recalbox_old for example to test in a clean share? I had this problem with the youtube addon and when I did this it solved, then I just moved the folders of the previous recalbox that interested me into the new share\recalbox.
        Version 4.1 is still unstable and it is recommended to use it only for testing and not for final use.
        Zodian Theme | #SNESProject
        Tony32 1 Reply Last reply Reply Quote 0
        • Tony32
          Tony32 @azvarel last edited by Tony32
          @azvarel said in Recalbox unstable and Kodi problems:
          @Tony32
          Thank you mate, will try it this eveening. I will grab a log too if it won't work.
          • Tony32
            Unfortunately it didn't work. Did a fresh install of 4.1 now so let's see how it goes..
            • Tony32
              Tony32 @Tony32 last edited by
              @Tony32 Okay, just tested on a fresh install. Twitch still doesnt work, just once out of like 10 tries or just pure luck. It tries to "open stream" and it just does nothing or a message with "one or more items failed to play".
              Same thing with the TV3 Play addon. Both of these addons work on my laptop running Linux Mint.
              Log:
              https://paste.ubuntu.com/24356378/
              • Tony32
                Tony32 @Tony32 last edited by Tony32
                This post is deleted!
                • Tony32
                  Can anyone confirm if your Twitch addon works in Kodi on recalbox?
                  • azvarel
                    @Tony32 tell me via chat the address of your repositories, to test them
