    Solved Disabling startup sound in 4.1 unstable?
    disabling startup sound 4.1 unstable
    7
    8
    5947
    • Ingo Werstler
      Ingo Werstler last edited by
      The startup screen on 4.1 comes with some pretty nice sound effect, however it's (probably) set to 100% volume and sometimes pretty annoying when I startup the raspberry in my cabinet while e.g. being on the phone. Can this sound be set to a lower volume or even be disabled?
      Ingo Werstler 1 Reply Last reply Reply Quote 0
      • Ingo Werstler
        Ingo Werstler @Ingo Werstler last edited by
        Well.. I did not find a customizable solution for it, but I got the tip, that this is the splash screen video. I removed the sound from the video file and uploaded it back into Recalbox. Problem solved, startup sequence is silent now 🙂
        • Ingo Werstler
          • plootje
            plootje last edited by
            where is the video ?
            srelysian 1 Reply Last reply Reply Quote 0
            • srelysian
              srelysian @plootje last edited by
              I know this topic is 2 months old but I figured I'd supply an easy answer in case someone else comes looking.
              First you need to remount the system to be writable:
              mount -o remount, rw /
              The file you are looking for is located here:
              cd /recalbox/system/resources/splash
              You can use ffmpeg to strip the audio out:
              ffmpeg -i recalboxintro.mp4 -c copy -an recalboxintro-nosound.mp4
              Then you can rename the original in case you ever want it back and replace it with the new one with the sound stripped out:
              mv recalboxintro.mp4 recalboxintro-orig.mp4
              mv recalboxintro-nosound.mp4 recalboxintro.mp4
              Dunuck 1 Reply Last reply Reply Quote 2
              • Dunuck
                Dunuck @srelysian last edited by
                @srelysian This worked out for me. So thank you for answering it, even after 2 months!
                • Fraaalesi
                  Fraaalesi last edited by
                  you can also lower the sound with:
                  ffmpeg -i recalboxintro.mp4 -vcodec copy -strict -2 -af "volume=-15dB" outputfile.mp4
                  • Dezzy
                    Dezzy last edited by
                    I'm new to this stuff. Where do I put in these commands? That intro sound is way too loud!
                    • ThomasD3
                      ThomasD3 last edited by
                      Awesome, thanks! that was definitely way too loud 🙂
