    Killer Instinct MAME retropie
    Your discoveries
    killer instinct mame retropie
    • azvarel
      azvarel last edited by
      I do not know if it is known to you, or if this is old, but for the case it appeared to me today:
      https://www.youtube.com/watch?v=-nNJnArwyrY
      and this
      https://github.com/libretro/mame2003-libretro/issues/38
      Zodian Theme | #SNESProject
      ZachGold 1 Reply Last reply Reply Quote 0
      • ZachGold
        ZachGold @azvarel last edited by
        @azvarel
        well, the emulation seems flawless. seems like an improvement over other n64 emulators. i never used scanline filters btw so i'm not sure
          I tried KI in advmame ... it was running at 5fps ...
          But I'm pretty sure it can't run at even 80% of the original speed on a pi3
          • markwkidd
            markwkidd last edited by
            Killer Instinct 1 and 2 should be working in MAME 2003 but there is a bug that currently prevents it. There is now a bounty open to raise the funds to attract a coder to fix this bug.
            The most likely way get these games running would be to contribute to the bounty: https://www.bountysource.com/issues/35638008-regression-in-killer-instinct-1-and-2-support
