    Unsolved PS3 Sixaxis Controller won't pair
    GamePad/GPIO/USB encoder
    ps3 controller raspberry pi 2 bluetooth recalbox emulationstatio
    • binlist
      binlist last edited by
      Hi I have used RetroPie way back and connecting a Sony Ps3 Sixaxis controller was a PITA but i managed.
      I have tried every option there is out in this forums and none work. Please lead me in the right direction as I will forever grateful.
      I have printed a copy of dmesg command.
      [ 0.000000] Booting Linux on physical CPU 0xf00
      [ 0.000000] Initializing cgroup subsys cpuset
      [ 0.000000] Initializing cgroup subsys cpuacct
      [ 0.000000] Linux version 4.1.13-v7 (root@6f4d5eb12471) (gcc version 4.9.3 (Buildroot 2016.02-git-dirty) ) #1 SMP PREEMPT Mon Feb 20 15:48:07 UTC 2017
      [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
      [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
      [ 0.000000] cma: Reserved 8 MiB at 0x2e400000
      [ 0.000000] Memory policy: Data cache writealloc
      [ 0.000000] On node 0 totalpages: 192512
      [ 0.000000] free_area_init_node: node 0, pgdat 80873000, node_mem_map add64000
      [ 0.000000] Normal zone: 1692 pages used for memmap
      [ 0.000000] Normal zone: 0 pages reserved
      [ 0.000000] Normal zone: 192512 pages, LIFO batch:31
      [ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
      [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
      [ 0.000000] PERCPU: Embedded 13 pages/cpu @aefae000 s20608 r8192 d24448 u53248
      [ 0.000000] pcpu-alloc: s20608 r8192 d24448 u53248 alloc=13*4096
      [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
      [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0xdef368e5 smsc95xx.macaddr=B8:27:EB:F3:68:E5 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p9 rootwait fastboot noswap ro
      [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
      [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      [ 0.000000] Memory: 744544K/770048K available (6043K kernel code, 534K rwdata, 1652K rodata, 420K init, 757K bss, 17312K reserved, 8192K cma-reserved)
      [ 0.000000] Virtual kernel memory layout:
      [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
      [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
      [ 0.000000] vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
      [ 0.000000] lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
      [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
      [ 0.000000] .text : 0x80008000 - 0x8078c0b4 (7697 kB)
      [ 0.000000] .init : 0x8078d000 - 0x807f6000 ( 420 kB)
      [ 0.000000] .data : 0x807f6000 - 0x8087bb54 ( 535 kB)
      [ 0.000000] .bss : 0x8087e000 - 0x8093b7dc ( 758 kB)
      [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [ 0.000000] Preemptible hierarchical RCU implementation.
      [ 0.000000] Additional per-CPU info printed with stalls.
      [ 0.000000] NR_IRQS:608
      [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
      [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
      [ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
      [ 0.000031] Switching to timer-based delay loop, resolution 52ns
      [ 0.000319] Console: colour dummy device 80x30
      [ 0.000556] console [tty3] enabled
      [ 0.000592] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
      [ 0.000616] pid_max: default: 32768 minimum: 301
      [ 0.000969] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [ 0.000991] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [ 0.002284] Initializing cgroup subsys blkio
      [ 0.002326] Initializing cgroup subsys memory
      [ 0.002360] Initializing cgroup subsys devices
      [ 0.002388] Initializing cgroup subsys freezer
      [ 0.002425] Initializing cgroup subsys net_cls
      [ 0.002497] CPU: Testing write buffer coherency: ok
      [ 0.002577] ftrace: allocating 20249 entries in 60 pages
      [ 0.051593] CPU0: update cpu_capacity 1024
      [ 0.051636] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
      [ 0.051653] [bcm2709_smp_prepare_cpus] enter
      [ 0.051773] Setting up static identity map for 0x8240 - 0x8274
      [ 0.111475] [bcm2709_boot_secondary] cpu:1 started (0) 18
      [ 0.111904] [bcm2709_secondary_init] enter cpu:1
      [ 0.111960] CPU1: update cpu_capacity 1024
      [ 0.111969] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
      [ 0.131461] [bcm2709_boot_secondary] cpu:2 started (0) 17
      [ 0.131815] [bcm2709_secondary_init] enter cpu:2
      [ 0.131849] CPU2: update cpu_capacity 1024
      [ 0.131857] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
      [ 0.151504] [bcm2709_boot_secondary] cpu:3 started (0) 17
      [ 0.151758] [bcm2709_secondary_init] enter cpu:3
      [ 0.151788] CPU3: update cpu_capacity 1024
      [ 0.151796] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
      [ 0.151886] Brought up 4 CPUs
      [ 0.151917] SMP: Total of 4 processors activated (153.60 BogoMIPS).
      [ 0.151927] CPU: All CPU(s) started in HYP mode.
      [ 0.151937] CPU: Virtualization extensions available.
      [ 0.152936] devtmpfs: initialized
      [ 0.177071] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [ 0.177369] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [ 0.178482] pinctrl core: initialized pinctrl subsystem
      [ 0.179283] NET: Registered protocol family 16
      [ 0.185192] DMA: preallocated 4096 KiB pool for atomic coherent allocations
      [ 0.186524] bcm2709.uart_clock = 48000000
      [ 0.191757] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [ 0.191774] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [ 0.191958] Serial: AMBA PL011 UART driver
      [ 0.192147] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
      [ 0.192707] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
      [ 0.263080] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
      [ 0.263126] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
      [ 0.263832] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
      [ 0.263852] bcm2708-dmaengine 3f007000.dma: dma_debug:0
      [ 0.264583] SCSI subsystem initialized
      [ 0.264840] usbcore: registered new interface driver usbfs
      [ 0.264959] usbcore: registered new interface driver hub
      [ 0.265112] usbcore: registered new device driver usb
      [ 0.265816] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-01-31 17:44
      [ 0.293307] Switched to clocksource arch_sys_counter
      [ 0.345332] FS-Cache: Loaded
      [ 0.345729] CacheFiles: Loaded
      [ 0.358982] NET: Registered protocol family 2
      [ 0.360398] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
      [ 0.360540] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
      [ 0.360733] TCP: Hash tables configured (established 8192 bind 8192)
      [ 0.360854] UDP hash table entries: 512 (order: 2, 16384 bytes)
      [ 0.360920] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
      [ 0.361264] NET: Registered protocol family 1
      [ 0.361766] RPC: Registered named UNIX socket transport module.
      [ 0.361785] RPC: Registered udp transport module.
      [ 0.361797] RPC: Registered tcp transport module.
      [ 0.361808] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [ 0.363086] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
      [ 0.364642] futex hash table entries: 1024 (order: 4, 65536 bytes)
      [ 0.380584] VFS: Disk quotas dquot_6.6.0
      [ 0.380998] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [ 0.383644] FS-Cache: Netfs 'nfs' registered for caching
      [ 0.384861] NFS: Registering the id_resolver key type
      [ 0.384950] Key type id_resolver registered
      [ 0.384964] Key type id_legacy registered
      [ 0.387733] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
      [ 0.387921] io scheduler noop registered
      [ 0.387945] io scheduler deadline registered (default)
      [ 0.388276] io scheduler cfq registered
      [ 0.390761] BCM2708FB: allocated DMA memory ee800000
      [ 0.390804] BCM2708FB: allocated DMA channel 0 @ f3007000
      [ 0.424337] Console: switching to colour frame buffer device 240x67
      [ 0.445905] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
      [ 0.447211] vc-cma: Videocore CMA driver
      [ 0.447228] vc-cma: vc_cma_base = 0x00000000
      [ 0.447241] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
      [ 0.447252] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
      [ 0.447487] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
      [ 0.464145] brd: module loaded
      [ 0.473251] loop: module loaded
      [ 0.474370] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
      [ 0.476244] Loading iSCSI transport class v2.0-870.
      [ 0.477165] usbcore: registered new interface driver smsc95xx
      [ 0.477246] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [ 0.677597] Core Release: 2.80a
      [ 0.677617] Setting default values for core params
      [ 0.677666] Finished setting default values for core params
      [ 0.878093] Using Buffer DMA mode
      [ 0.878111] Periodic Transfer Interrupt Enhancement - disabled
      [ 0.878121] Multiprocessor Interrupt Enhancement - disabled
      [ 0.878133] OTG VER PARAM: 0, OTG VER FLAG: 0
      [ 0.878151] Dedicated Tx FIFOs mode
      [ 0.878534] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
      [ 0.878574] FIQ FSM acceleration enabled for :
      [ 0.878574] Non-periodic Split Transactions
      [ 0.878574] Periodic Split Transactions
      [ 0.878574] High-Speed Isochronous Endpoints
      [ 0.878598] dwc_otg: Microframe scheduler enabled
      [ 0.878669] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80415604
      [ 0.878689] WARN::hcd_init_fiq:413: FIQ ASM at 0x80415974 length 36
      [ 0.878710] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf89a000
      [ 0.878756] dwc_otg 3f980000.usb: DWC OTG Controller
      [ 0.878810] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
      [ 0.878856] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
      [ 0.878911] Init: Port Power? op_state=1
      [ 0.878924] Init: Power Port (0)
      [ 0.879234] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
      [ 0.879257] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [ 0.879275] usb usb1: Product: DWC OTG Controller
      [ 0.879292] usb usb1: Manufacturer: Linux 4.1.13-v7 dwc_otg_hcd
      [ 0.879308] usb usb1: SerialNumber: 3f980000.usb
      [ 0.880258] hub 1-0:1.0: USB hub found
      [ 0.880332] hub 1-0:1.0: 1 port detected
      [ 0.880830] dwc_otg: FIQ enabled
      [ 0.880846] dwc_otg: NAK holdoff enabled
      [ 0.880857] dwc_otg: FIQ split-transaction FSM enabled
      [ 0.880896] Module dwc_common_port init
      [ 0.881288] usbcore: registered new interface driver usb-storage
      [ 0.881576] mousedev: PS/2 mouse device common for all mice
      [ 0.882432] bcm2835-cpufreq: min=600000 max=900000
      [ 0.884960] sdhci: Secure Digital Host Controller Interface driver
      [ 0.884969] sdhci: Copyright(c) Pierre Ossman
      [ 0.885294] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
      [ 0.885308] mmc-bcm2835 3f300000.mmc: DMA channels allocated
      [ 0.923403] sdhci-pltfm: SDHCI platform and OF driver helper
      [ 0.923819] ledtrig-cpu: registered to indicate activity on CPUs
      [ 0.923953] hidraw: raw HID events driver (C) Jiri Kosina
      [ 0.924115] usbcore: registered new interface driver usbhid
      [ 0.924123] usbhid: USB HID core driver
      [ 0.924367] Initializing XFRM netlink socket
      [ 0.924402] NET: Registered protocol family 17
      [ 0.924553] Key type dns_resolver registered
      [ 0.924985] Registering SWP/SWPB emulation handler
      [ 0.926980] registered taskstats version 1
      [ 0.931478] vc-sm: Videocore shared memory driver
      [ 0.931496] [vc_sm_connected_init]: start
      [ 0.932063] [vc_sm_connected_init]: end - returning 0
      [ 0.939112] Waiting for root device /dev/mmcblk0p9...
      [ 0.960357] mmc0: host does not support reading read-only switch, assuming write-enable
      [ 0.962319] mmc0: new high speed SDHC card at address 0001
      [ 0.962772] mmcblk0: mmc0:0001 00000 14.6 GiB
      [ 0.966891] mmcblk0: p1 p2 < p5 p6 p7 p8 p9 p10 >
      [ 1.044072] EXT4-fs (mmcblk0p9): couldn't mount as ext3 due to feature incompatibilities
      [ 1.044585] EXT4-fs (mmcblk0p9): couldn't mount as ext2 due to feature incompatibilities
      [ 1.055882] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
      [ 1.055938] VFS: Mounted root (ext4 filesystem) readonly on device 179:9.
      [ 1.065018] devtmpfs: mounted
      [ 1.065525] Freeing unused kernel memory: 420K (8078d000 - 807f6000)
      [ 1.073412] Indeed it is in host mode hprt0 = 00021501
      [ 1.253369] usb 1-1: new high-speed USB device number 2 using dwc_otg
      [ 1.253538] Indeed it is in host mode hprt0 = 00001101
      [ 1.454859] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
      [ 1.454881] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [ 1.456025] hub 1-1:1.0: USB hub found
      [ 1.456209] hub 1-1:1.0: 5 ports detected
      [ 1.638882] udevd[99]: starting version 3.1.5
      [ 1.668877] random: udevd urandom read with 68 bits of entropy available
      [ 1.733420] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
      [ 1.834115] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
      [ 1.834158] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [ 1.837519] smsc95xx v1.0.4
      [ 1.853079] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
      [ 1.897285] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:f3:68:e5
      [ 1.973423] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
      [ 2.074038] usb 1-1.4: device descriptor read/all, error -32
      [ 2.153391] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
      [ 2.259214] usb 1-1.4: New USB device found, idVendor=0a12, idProduct=0001
      [ 2.259242] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [ 2.353353] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
      [ 2.522588] usb 1-1.5: New USB device found, idVendor=054c, idProduct=0268
      [ 2.522607] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [ 2.522619] usb 1-1.5: Product: PLAYSTATION(R)3 Controller
      [ 2.522630] usb 1-1.5: Manufacturer: Sony
      [ 2.793329] usb 1-1.3: new low-speed USB device number 7 using dwc_otg
      [ 2.908510] usb 1-1.3: New USB device found, idVendor=1a2c, idProduct=0e24
      [ 2.908529] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [ 2.908540] usb 1-1.3: Product: USB Keyboard
      [ 2.908551] usb 1-1.3: Manufacturer: SEM
      [ 2.920020] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1A2C:0E24.0002/input/input0
      [ 2.973589] hid-generic 0003:1A2C:0E24.0002: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-3f980000.usb-1.3/input0
      [ 2.984351] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1A2C:0E24.0003/input/input1
      [ 3.043560] hid-generic 0003:1A2C:0E24.0003: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-3f980000.usb-1.3/input1
      [ 3.108653] Bluetooth: Core ver 2.20
      [ 3.108773] NET: Registered protocol family 31
      [ 3.108786] Bluetooth: HCI device and connection manager initialized
      [ 3.108815] Bluetooth: HCI socket layer initialized
      [ 3.108834] Bluetooth: L2CAP socket layer initialized
      [ 3.108871] Bluetooth: SCO socket layer initialized
      [ 3.122473] usbcore: registered new interface driver btusb
      [ 3.667028] random: nonblocking pool is initialized
      [ 6.198271] input: Sony PLAYSTATION(R)3 Controller as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:054C:0268.0001/input/input2
      [ 6.199121] sony 0003:054C:0268.0001: input,hiddev0,hidraw2: USB HID v1.11 Joystick [Sony PLAYSTATION(R)3 Controller] on usb-3f980000.usb-1.5/input0
      [ 6.458885] EXT4-fs (mmcblk0p10): couldn't mount as ext3 due to feature incompatibilities
      [ 6.459473] EXT4-fs (mmcblk0p10): couldn't mount as ext2 due to feature incompatibilities
      [ 6.528504] EXT4-fs (mmcblk0p10): recovery complete
      [ 6.529646] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
      [ 9.227202] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [ 9.227228] Bluetooth: BNEP filters: protocol multicast
      [ 9.227251] Bluetooth: BNEP socket layer initialized
      [ 9.289017] Bluetooth: RFCOMM TTY layer initialized
      [ 9.289067] Bluetooth: RFCOMM socket layer initialized
      [ 9.289096] Bluetooth: RFCOMM ver 1.11
      [ 11.254148] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
      [ 11.254208] Bluetooth: HIDP socket layer initialized
      [ 13.765729] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
      [ 15.321348] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
      [ 17.558123] NET: Registered protocol family 10
      [ 395.692305] usb 1-1.5: USB disconnect, device number 6
      [ 397.725348] input: PLAYSTATION(R)3 Controller as /devices/virtual/input/input3
      [ 438.706046] usb 1-1.3: USB disconnect, device number 7
      [ 462.755008] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
      [ 463.041278] usb 1-1.3: New USB device found, idVendor=054c, idProduct=0268
      [ 463.041308] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [ 463.041336] usb 1-1.3: Product: PLAYSTATION(R)3 Controller
      [ 463.041347] usb 1-1.3: Manufacturer: Sony
      [ 463.270401] input: Sony PLAYSTATION(R)3 Controller as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:054C:0268.0004/input/input4
      [ 463.273956] sony 0003:054C:0268.0004: input,hiddev0,hidraw0: USB HID v1.11 Joystick [Sony PLAYSTATION(R)3 Controller] on usb-3f980000.usb-1.3/input0
      [ 465.589627] usb 1-1.3: USB disconnect, device number 8
      [ 742.597104] usb 1-1.2: new low-speed USB device number 9 using dwc_otg
      [ 742.711410] usb 1-1.2: New USB device found, idVendor=1a2c, idProduct=0e24
      [ 742.711434] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [ 742.711445] usb 1-1.2: Product: USB Keyboard
      [ 742.711457] usb 1-1.2: Manufacturer: SEM
      [ 742.725070] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1A2C:0E24.0005/input/input5
      [ 742.778155] hid-generic 0003:1A2C:0E24.0005: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-3f980000.usb-1.2/input0
      [ 742.787382] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1A2C:0E24.0006/input/input6
      [ 742.848116] hid-generic 0003:1A2C:0E24.0006: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-3f980000.usb-1.2/input1
      [ 1099.768999] usb 1-1.3: new full-speed USB device number 10 using dwc_otg
      [ 1099.938443] usb 1-1.3: New USB device found, idVendor=054c, idProduct=0268
      [ 1099.938472] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [ 1099.938484] usb 1-1.3: Product: PLAYSTATION(R)3 Controller
      [ 1099.938495] usb 1-1.3: Manufacturer: Sony
      [ 1100.022671] input: Sony PLAYSTATION(R)3 Controller as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:054C:0268.0007/input/input7
      [ 1100.023970] sony 0003:054C:0268.0007: input,hiddev0,hidraw2: USB HID v1.11 Joystick [Sony PLAYSTATION(R)3 Controller] on usb-3f980000.usb-1.3/input0
      100.7k
