    Recalbox per Windows
    Italiano
    recalbox per windows
    • Manuel Giuseppe Trizzo
      Manuel Giuseppe Trizzo last edited by
      Avete mai pensato a una versione di Recalbox, compatibile con Windows 10?
      Have you ever thought about a version of Recalbox, compatible with Windows 10?
      jackalpret 1 Reply Last reply Reply Quote 0
      • jackalpret
        jackalpret Translator @Manuel Giuseppe Trizzo last edited by
        @Manuel-Giuseppe-Trizzo i think it cant be possible... BUT, you can use in one pendrive intel/pc version ... so with liveusb you can have recalbox on any pc
        • mrchat9
          mrchat9 last edited by
          There's a fork called "batocera Linux"...yon can connect an external HDD and install BUT there are many problem...If you have not practice with the root permission is very difficult to copy rom or bios into system
          jackalpret 1 Reply Last reply Reply Quote 1
          • jackalpret
            jackalpret Translator @mrchat9 last edited by
            @mrchat9 said in Recalbox per Windows:
            batocera isnt oficial release, but recalbox has official release (unstable at the moment) to run in PC (intel) computers ...
            https://archive.recalbox.com/updates/v1.0/unstable/
