    DOS in recalbox 4.1 how to set the joypad ?
    Emulator Arcade/PC/Console
    dos recalbox 4.1 joypad
    • Cthulhus
      Cthulhus last edited by
      Hello,
      Just added a game and it work and it's fast but I don't kow how and where can I configure the game for the joystick ? I remember, when I was young, I played that game with a joystick.
      Maybe it's too early?
      Thanks
      C'était mieux avant :-)
      • Cthulhus
        I finally found. Just need to plug a keyboard 🙂
        • simba51
          simba51 last edited by
          Exact. I also use the keyboard and mouse, but for some games, I would have liked to have used the joystick, and I have not found how to detect it in DOSBOX.
          Cartes RPi Zéro 2 W - RPi Zéro W - RPi400 - RPi 4/4Gb - RPi 3b - RPi 3b+ - RPi 3 a+
          Stockage 16Gb Sandisk, 32Gb Samsung et clé usb 64Gb & 128Gb
          2 manettes PS3 Freegun Bluetooth - 2 manettes 8BitDo SF30 Pro Bluetooth
          • max216
            max216 last edited by
            hello all,
            long time ago, when players like me have played on DOS, we was having the same troubles ^^
            so I have tried about 40 games in recalbox dosbox and some very old like double dragon 2 work, the newers can have the joypad config in settings, that work with PS3 gamepads just fine
            • sdlvivian
              sdlvivian last edited by
              Hello 😉
              I'm having problems with getting dosbox to work. I followed the readme and dosbox launches but after you see the dosbox logo it backs into the emulationstation menu again. I've tried multiple games with the same result. The last time I had similar errors it was from incorrect bios files and the improper resolution (dreamcast). Any input would be greatly appreciated.
              Thanks
