    [RELEASE] Zodian - 1080 + Music
    Themes & Interface
    [release] zodian 1080 music
    7
    24
    12559
    • maximus37
      maximus37 last edited by maximus37
      First off, I'd like to thank @azvarel and @Víctor-Téllez. I've taken the Zodian theme that azvarel worked on, doubled the image sizes for clarity on 1080p screens, and then added the system music from Victor's custom simplelight theme he made.
      Hope you like the small updates! And again, thanks for the work guys!
      https://drive.google.com/open?id=0Bz3zor1-dmWcY1FINm5RbUlEdkE
      • azvarel
        azvarel last edited by
        Nice Job!
        Beware only of WSOD
        Zodian Theme | #SNESProject
        maximus37 1 Reply Last reply Reply Quote 0
        • maximus37
          maximus37 @azvarel last edited by
          @azvarel Thanks!
          Do you mean for missed systems ?
          azvarel 1 Reply Last reply Reply Quote 0
          • azvarel
            azvarel @maximus37 last edited by
            @maximus37 Above 5 systems the ES is broken 😞 so I did not do it in 1080p
            • makination
              makination last edited by makination
              Anybody tested it? The system crashes or not?
                It is not a problem with this theme specifically, but all themes using 1 background image with a HD resolution by system in ES.
                Vram is filled with less that 10 systems activated, and ES crash during boot (white screen of death - WOSD).
                • azvarel
                  I tested it, I had a lot of headaches thinking it was my tv problem
                  https://forum.recalbox.com/topic/5340/problem-with-tv-samsung-40
                  • azvarel
                    @azvarel said in Problem with TV Samsung 40":
                    I found out why the recalbox is catching on TV, at 1080p resolution, it was the zoid theme that was messing with the recalbox.
                    I put the default recalbox theme and it is working normally.
                    The issue is that the zoid theme used a file with resolution 1920x1080, in .jpg and by proper attempt, because I did not find anything referring to WSOD at the time, I did compiling .png from the backgrounds and only then realized that the calculation that ES made was Based on resolution rather than file size.
                    • maximus37
                      Hmmm, I will try it again soon enough, I didn't crash on startup, but I'll cycle through all my systems and then load a few games, do some back and forth.
                      • azvarel
                        Tell me what your tv resolution, let's do some experiments
                        • maximus37
                          maximus37 @azvarel last edited by maximus37
                          @azvarel I'm on a 1080p tv, I'll let you know what I get as a result.
                          Btw, if the 1080 images do cause a problem (which I'm assuming they will), what about 720 resolution, is that still too high?
                          • azvarel
                            1080p: about 10
                            720p: about 20
                            480p: about 40/45
                            Once vram filled, you'll have a WSOD (White Screen Of Death) in ES
                            • maximus37
                              @azvarel Wow! 😮 that's something I definitely wasn't aware of.
                              Thanks for the info!
                              • azvarel
                                That's why I did it in 576p
                                • maximus37
                                  @azvarel : Ok, here is my setup:
                                  RPi2 with 16 systems. Recalbox installed on an SD card with everything else on my usb key (roms, themes, etc.)
                                  I cycled through all my systems back and forth, then cycled through all the detail screens and then back to the system screens. So far I was unable to crash ES.
                                  But I'll keep trying.... my setup is still a work in progress, thats why I only have 16 systems.
                                  So now I'm wondering....does it have to do with the RESOLUTION of the images, or the FILE SIZES that causes the crash? Hmmmm.....
                                  • Nainain
                                    Nainain last edited by
                                    Merci!
                                    J'adore ce thème, clair et épuré! 😉
                                    Un esprit saint dans un porc sain!
                                    • azvarel
                                      @maximus37 said in [RELEASE] Zodian - 1080 + Music:
                                      RESOLUTION OF THE IMAGES
                                      • RetroWilly
                                        RetroWilly last edited by
                                        Nice theme!
                                        About the WSOD. This is the reason i keep background images in my themes on 480p for now , since i want to keep it as stable as possible. One of the mod's pointed me on that on time.
                                        Cropping images for now it is.
                                        Hello :)
                                        • summunx
                                          summunx Banned last edited by
                                          alt text
                                          tengo este error , alguna solucion?
                                          • makination
                                            I don't understand yet if i install this theme my system will crash. I've got 17 systems on Recalbox right now, will i get WSOD if i install this?
                                            What to do if WSOD? The only solution is format sd card and reinstall all?
                                            Thanks!
