    Solved Giochi PSX
    Italiano
    giochi
    2869
    • Enrico Rossetto
      Enrico Rossetto last edited by
      Capita spesso di trovare "iso" che in raltà sono tanti file bin con le varie tracce. Come si possono gestire in recalbox? si possono fare delle sotto-cartelle? E' possibile fare lo scrape dei giochi anche in questo modo? O è meglio trovare delle "iso" composte da un unico file?
      GRAZIE!
      Happens to download "isos" that are many bin files of any track of the CD. How can I handle these in recalbox? It is possible to use a sub-folder structure? Does the "scrape" function anyway work? Or perhaps is better to have a single-file "iso"?
      Many thanks!
      azvarel 1 Reply Last reply Reply Quote 0
      • azvarel
        azvarel @Enrico Rossetto last edited by
        @Enrico-Rossetto
        http://recalbox-wiki-rtfd.readthedocs.io/en/4.0/EN/Convert-iso-track-wav-bin-to-bin-cue-(EN)/
        I use the .pbp (or eboots for a PSP) files for PSX emulation. No need to mess with .cue, .mp3, etc...
        Zodian Theme | #SNESProject
        Enrico Rossetto 2 Replies Last reply Reply Quote 0
        • Enrico Rossetto
          Enrico Rossetto @azvarel last edited by
          @azvarel a MEGA thanks! You solved me a big problem. Sorry if I didn't search deep in the forum.
          • Enrico Rossetto
            @azvarel said in Giochi PSX:
            Are the .pbp better than standard isos?
            • azvarel
              azvarel last edited by azvarel
              @Enrico-Rossetto
              I think in addition to having a smaller size because there is a file compression and it is the same thing, I have done this since psx emulation on own psp, look for psx 2 psp or psx on psp isos you will find a great collection of download .pbp files
              Enrico Rossetto 1 Reply Last reply Reply Quote 0
              • Enrico Rossetto
                @azvarel many many many thanks!
