    [Recalbox 4.0.2] Rewind problems with rp3
    [recalbox 4.0.2] rewind rp3
    • bemandrill
      bemandrill last edited by
      Hi! I have always had problems with the rewind option on. The N64 roms or CPS didnt work. For that reason, I turn off the rewind option (before by conf file).
      The problem is that yesterday I connected my rp3 to Internet in order to update the system. The problem is that Recalbox works bad, and also the roms. It looks like as the rewind option is ON, but no, the option in the menu appears off. But if I load some rom, I can rewind, then... Could the rewind option apper off but to be on in the conf file?
      The problem of performance of the system with the rewind option ON is normal?
      Thanks
      100.6k
