    internal Bluetooth+NES30
    GamePad/GPIO/USB encoder
    internal bluetoothnes30
    • jimmirehman
      jimmirehman last edited by jimmirehman
      Once I get the NES30 paired, After a reboot, the NES30 will not connect. I hold down Start+R for 3 seconds, the controller blinks and blinks and blinks, never to connect to the recalbox again. Turning off the controller and starting again with just holding down the Start button for 3 seconds, same thing.
      What is the proper way to connect this controller?
      EDIT: Pi3, recalbox OS 4.1 unstable (Had same issues with 4.0 & 4.01)
        Hello @jimmirehman
        try this may be : https://forum.recalbox.com/topic/6517/4-1-unstable-need-testers-for-a-bluetooth-major-improvement
        jimmirehman 1 Reply Last reply Reply Quote 0
        • jimmirehman
          jimmirehman @acris last edited by
          @acris didn't work. Made it worse
