    Internal Bluetooth PI3
    GamePad/GPIO/USB encoder
    internal bluetooth pi3
    • duri3
      duri3 last edited by
      So I have installed recalbox 4.1 unstable, how to enable the internal Bluetooth so I can pair my PS3 Controller with it? It does work with my bt dongle but I don't know how to activate the internal bt module.
      Will the pairing work the same way, e g connect usb for 10 seconds disconnect and press PS Button?
        Substring @duri3 last edited by
        @duri3 it's activated by default. Just remove your bt dongle to be sure. You'll have to reset your ps3 pad and pair it again. Make sure your ps3 driver is set to bluez (the upgrade process needs to be fixed)
        • duri3
          duri3 last edited by Substring
          So if I understood you right, I have to change the recalbox.conf like this:
          controllers.ps3.enabled=1
          ## Choose an driver beetween official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
          controllers.ps3.driver=bluez
            @duri3 Sir Yes Sir !
            I edited your post for a better layout 🙂
            • duri3
              Thanks again for your support! Recalbox is really a amazing project!
