    4.1 Using Bluetooth & PS4 Controller
    GamePad/GPIO/USB encoder
    4.1 bluetooth ps4
    • tdelios
      tdelios last edited by
      I installed the unstable version of 4.1 which looks like it went through without a problem.
      The only issue I am having which I am specifically was waiting for is the Bluetooth use for the PS4 controller.
      I paired the Pi3 with the PS4 controller, but the PS4 controller will not work when pressing any of its buttons or joysticks doesn't do anything.
      I assumed that the PLAYER1 controller setup would have an option other than DEFAULT to switch to Bluetooth, but it doesn't. So not sure if there are still bugs with the Bluetooth feature in 4.1 to support PS4 controllers.
        Substring @tdelios last edited by
        @tdelios is your pad showing when you ruen sdl2-jstest ?
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @Substring last edited by
          @Substring how do I do that?
            @tdelios Connect through SSH, run sdl2-jstest -lafair
