    Solved Can I sell a system with Recall OS installed?
    Your recalbox
    sell recall installed
    7
    9
    4681
    • Pinocho_2010
      Pinocho_2010 last edited by
      Hello, I have created a small console out of wood to house my raspberry pi 3. Then I installed this awesome software to an SD card and it was truly amazing. Anyway, I took it to school and showed some people, and they said they want one. I told them I would sell one, because making the box was really hard. I just wanted to know if I could include this software in an SD card and sell the console to them like that. No extra roms will be included beside that ones that are already included with the base installation.
      Also, if not, is there some software that I can sell it with?
      Link to what I built. http://imgur.com/a/9GGKK
      Thanks,
      Pinocho_2010
      • Nachtgarm
        Nachtgarm last edited by
        I summon the all-father of recalbox, @digitalLumberjack
          voljega Banned @Pinocho_2010 last edited by voljega
          @Pinocho_2010 What is the purpose of making a such big, almost totally empty big box ? It could be like 4 or 5 times smaller ?
          Also why use male usb instead of female ones which wouldn't stick out of the box ?
            Substring @Pinocho_2010 last edited by
            @Pinocho_2010 You mustn't sell Recalbox https://github.com/recalbox/recalbox-os/blob/master/LICENCE.md
            • godhunter74
              godhunter74 last edited by godhunter74
              Maybe You can sell your box without recalbox and give them some tutorial links ...
              Relier un écran I2C et afficher des informations sur les roms
              • digitaLumberjack
                @Pinocho_2010 nope 🙂
                • Neil_Hines
                  Neil_Hines last edited by
                  Hi, guys, I can get small confused. Really can we sell the system with Recall OS installed?
                    voljega Banned @Neil_Hines last edited by
                    @Neil_Hines NO as stated at least two times on this subject
                      Substring @Neil_Hines last edited by
                      @Neil_Hines The recalbox license prohibits it, as well as some software licenses inside Recalbox. So no, you can't.
