    Stretch emulators to fullscreen
    stretch fullscreen
    • mmmRetro
      mmmRetro last edited by
      OK... here goes...
      I am running recalbox on a RPI3 with composite out connected to a 13" tube television. Most emulators have black bars on the sides only. Is there a way to stretch these emulators so that they fill the screen entirely like they did on the original consoles?
      I have adjusted the overscan values to get emulationstation to fill the screen correctly, hoping that this would make the emulators follow suit, but no dice.
      Any help is greatly appreciated.
      Thanks
      • mmmRetro
        mmmRetro last edited by mmmRetro
        Here are examples, the only one that truly outputs to fullscreen is GBA
        http://imgur.com/a/4n2gW
        Also here are the contents of my boot/config.txt and recalbox.conf
        config.txt = http://pastebin.com/6jCPaged
        recalbox.conf = http://pastebin.com/Zie8EjbL
        Thanks again.
        • mmmRetro
          figured out that i need all retroarch emulators to be displayed in 3:2 aspect ratio. now to figure out how to get them all in that without having to create a custom config for each emulator.
            Substring @mmmRetro last edited by
            @mmmRetro you can find the parameter name for the retroarch.cfg file, and add it yourself to /recalbox/share/system/configs/retroarch/retroarchcustom.cfg. It should work. The file is xan also be found through the windows network shares
            • mmmRetro
              adjusted this line. finally figured it out
              aspect_ratio_index = 6
