    Solved Snes emulation performance disapointing
    Emulator Arcade/PC/Console
    snes performance disapointing
    • Martbob
      Martbob last edited by
      I have a Pi3 with recalbox 4.0 installed.
      I tried a couple of games and I have concern.
      I tried Super Punch Out witch yes is playable but as frequent slow down almost 80% of the time. The music crackle always and never at the right speed.
      Is this a normal behaviour with a Pi3 (not overclocked but with heatpad) for snes emulation.
      I tried the same game on my computer and snes9x and it was flawless.
      My Pi3 is connected only with HDMI and I tried putting rom on the SD and on a USB stick. I use a ps3 controller connected with USB.
      Is there something Im doing wrong?
      I tough by buying Pi3 I would get the same result that I get with my computer for SNES. Every forum talks about N64 performance but my problem is with snes.
      For the record I also tried Retropie with the same result.
      • Martbob
        I tried Pocketsnes emulator instead of snes9x-next and it seams to fix a lot of problem.
        Is there a drawback to using pocketsnes ?
        DjLeChuck 1 Reply Last reply Reply Quote 0
        • DjLeChuck
          DjLeChuck @Martbob last edited by
          @Martbob Some games prefers an emulator instead of another. You have made the good choice by testing another one than the default. 🙂
          Martbob 1 Reply Last reply Reply Quote 0
          • Martbob
            Martbob @DjLeChuck last edited by
            @DjLeChuck
            Ok but I never got clear sound on any game with snes9x-next emulator is that normal ?
