    Solved Sixaxis bluetooth and n64
    GamePad/GPIO/USB encoder
    sixaxis bluetooth
    3197
    • fireup
      fireup last edited by
      My sixaxis ps3 controller don't work when the n64 emulator start.
      It only happen when i'm using bluetooth conexión.
      But i can back to the front with hotkey...
      If the sixaxis are wired conect there is no problem.
      And the leds stop blinking and stay turned on the led 4.
        Try to reconfigure your pad in ES then tell us how it went
        fireup 1 Reply Last reply Reply Quote 0
        • fireup
          This post is deleted!
          • fireup
            fireup @Substring last edited by
            @Substring no way.... After reconfigure in ES.. continue as before...
              Substring @fireup last edited by
              @fireup Do you have some other pads plugged ?
              • fireup
                @Substring nop...I only have the sixaxis bluetooth conection. and when the n64 starts, the player 4 led stay on
                  @fireup nevermind the led, the one thing to know with N64 is that it's the only emulator where we can't force (yet) padds/players order. So that's why i think you have some other "pads" plugged
                  • fireup
                    Finally i found the problem.
                    I had activated gpio controllers, and when the n64 emulator starts, assigned the gpio 1 and 2 to 1 and player 2, and the sixaxis was the player 3.
                    I solved configuring gpio to 0 in recalbox.conf and It works fine.
                    Thanks for all.
                      @fireup Glad you made it 🙂
