    [Solved] USB audio only playing in right speaker
    usb audio
    • IT_Freely
      IT_Freely last edited by IT_Freely
      Hello all.
      Recently I acquired a generic 5.1 USB audio adapter. It works as far as stereo on its own with Windows, etc but I'm running into issues with recalbox.
      I have it connected via USB and basically set alsa-base.conf to use it first . After an initial reboot it detects and I can hear the background menu music playing but only over the right speaker. I can't hear the background sounds like menu selection etc. In the settings system volume is set to 0 and keeps defaulting to it.
      I did an alsamixer from the command line and all channels are up correctly and not muted.
      In name, audio again only plays from the right speaker. Cables are definitely good.
      I can't figure out with recalbox where to fix this. Do I need to edit a config somewhere else to get the USB audio working or is the alsa base file not needed?
      Edit: Solved it. Apparently my headphones are having some jack issues. Oye. Figures it starts when I start testing 🙂
      I lugged my 5.1 creative speaker setup down to the basement and plugged in and it's all working as expected and sounds fantastic!
