    Bluetooth Adapter
    bluetooth adapter
    • anthonyjclarke
      anthonyjclarke last edited by
      Hi Any particular models / chipsets supported to enable PS3 Controllers? Want to make sure I buy the correct one. Thanks
      • digitaLumberjack
        Hi pal, yes see the wiki entry i just made : https://github.com/digitalLumberjack/recalbox-os/wiki/Compatibility-(EN) many dongle are compatible, just avoid really cheap ones because you will have a lag on controllers. See Logilink, CSL, Asus dongle on amazon. My experience tells me you will have to get one > 7$ 🙂
