    PS3 Gasia controller not pairing with RB 4.0.0
    GamePad/GPIO/USB encoder
    ps3 gasia pairing 4.0.0
    3957
    • leriton
      leriton last edited by
      Hi everyone,
      Thanks for this amazing project!
      I'm trying to pair my PS3 Gasia controllers with Recalbox 4.0.0, and facing some difficulties. Those controllers worked fine with RB 3.2 with some adjustments 😉
      What I have done:
      • reset the controllers
      • edited recalbox.conf for Gasia controllers (see below)
      • followed pairing process
      Am I missing something obvious? Thanks in advance for the support!
      /var/log/messages
      Dec  6 21:17:27 RECALBOX user.info kernel: [ 1168.127425] usb 1-1.2: new full-speed USB device number 14 using dwc_otg
      Dec  6 21:17:27 RECALBOX user.info kernel: [ 1168.230708] usb 1-1.2: New USB device found, idVendor=054c, idProduct=0268
      Dec  6 21:17:27 RECALBOX user.info kernel: [ 1168.230743] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      Dec  6 21:17:27 RECALBOX user.info kernel: [ 1168.230756] usb 1-1.2: Product: PS(R) Gamepad
      Dec  6 21:17:27 RECALBOX user.info kernel: [ 1168.230767] usb 1-1.2: Manufacturer: Gasia Co.,Ltd
      Dec  6 21:17:27 RECALBOX user.info kernel: [ 1168.241859] input: Gasia Co.,Ltd PS(R) Gamepad as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:054C:0268.000B/input/input9
      Dec  6 21:17:27 RECALBOX user.info kernel: [ 1168.245920] sony 0003:054C:0268.000B: input,hiddev0,hidraw2: USB HID v1.11 Joystick [Gasia Co.,Ltd PS(R) Gamepad] on usb-3f980000.usb-1.2/input0
      Dec  6 21:17:43 RECALBOX user.info kernel: [ 1184.021206] usb 1-1.2: USB disconnect, device number 14
      Dec  6 21:17:51 RECALBOX daemon.err bluetoothd[309]: Refusing input device connect: No such file or directory (2)
      Dec  6 21:17:51 RECALBOX daemon.warn bluetoothd[309]: Can't find device agent
      Dec  6 21:17:51 RECALBOX daemon.err bluetoothd[309]: input: authorization for 00:1A:7D:DA:71:0E failed: Operation not permitted (-1)
      recalbox.conf (controller section):
      controllers.ps3.enabled=1
      ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
      controllers.ps3.driver=gasia
      controllers.xboxdrv.enabled=0
      ## GPIO Controllers
      controllers.gpio.enabled=0
      controllers.gpio.args=map=1,2
      ## DB9 Controllers
      controllers.db9.enabled=0
      ## db9 arguments
      controllers.db9.args=map=1
      ## Gamecon controllers
      controllers.gamecon.enabled=0
      ## gamecon_args
      controllers.xarcade.enabled=0
      • leriton
        I would love to provide more information if you point me where to find it.
        Feel free to ask for details, as I said, I'm probably missing something.
        Cheers!
          Substring @leriton last edited by
          @leriton Check all the drivers. GAsia pads are the most complicated ones as they really have their very own protocol that only partly complies with the genuine PS3.
          Remember to plug the pad on USB for a good 10 seconds. The pad should rumble after a while. Once it rumbles, unplug it, and press the home button.
          Please try the official driver as it has a few hacks for gasia.
          • leriton
            Will try this, thanks for your suggestion.
            Those exact same controllers works with Recalbox 3.2 using Gasia sixad binaries, see this thread (french) : https://forum.recalbox.com/topic/397/impossible-d-appairer-les-manettes-force-disconnect-of/7
            Is it possible that Gasia drivers suddenly stopped to work for my controllers?
              @leriton the drivers evolved since 3.2, that is the real reason. The official driver works with my gasia pad, i guess ypu are not as lucky as me
              • leriton
                And now it works with official drivers! Thanks a lot for your help, really appreciate.
                Cheers!
