    Xbox One Controller Not Working
    GamePad/GPIO/USB encoder
    xbox
    7
    11
    11160
    • Brad
      Brad last edited by Brad
      I've been using the the latest version of Recalbox with 4 x 360 wired controllers (2 genuine, 2 3rd party) and it's been working ok by enabling xboxdrv and disabling the PS3 driver. Sometimes one of the 3rd party ones will drop out and stop working, ie change from constant light indicating controller number to all flashing.
      Anyway, I disconnected all the 360 controllers and tried an Xbox One controller with a USB cable. It didn't work at all in the menu. Also, I tried my Xbox Elite controller and after powering up the Pi, it seemed to be booting from the controller. Strange.
      Anyway, is there an extra step I need to do to get the Xbox One controllers working?
      Thanks
        Xbox one elite will be supported in the next release 4.1
        Brad 1 Reply Last reply Reply Quote 0
        • Brad
          Brad @rockaddicted last edited by Brad
          @rockaddicted
          Thanks. Any reason why the normal Xbox One controller wouldn't work? I've tried both models - one with the 3.5mm jack and one without.
          Is there any special configuration or process required? The Xbox light is lit on the controller like it has connected ok but I can't navigate the menus. It is the only controller connected.
          All of the 360 controllers work fine when they are connected (I have enabled xboxdrv and disabled ps3).
            Because Microsoft is a stupid manufacturer, and each time it release a new firmware or controller version, breaks the compatibility. So we have to patch driver.
            • Brad
              @rockaddicted 🙂 Thanks again for your help!
              • Tobias_Ha
                Tobias_Ha last edited by
                Any chance that this controller will be supported in the next update too?
                https://www.microsoftstore.com/store/msusa/en_US/pdp/Xbox-Controller-and-Wireless-Adapter-for-Windows/productID.325921000
                Thank you
                Tobias
                  humm it is a standard xboxone gamepad ?
                  So, yes should be compatible on 4.1, but ONLY in USB mode.
                  Billservo acris 2 Replies Last reply Reply Quote 0
                  • DxPepper
                    DxPepper last edited by
                    The XBox One Controller without the 3,5mm Jack works fine with usb cable for me. Without any configuration-orgy 🙂
                    After reading your post, i tried it out with my elite controler (including last firmware update) and it works also fine.
                    Maybe important: i have removed the batteries before.
                    My Recalbox Version is 4.0, it runs on a raspi 3.
                    • Billservo
                      Billservo @rockaddicted last edited by
                      Thanks, @rockaddicted.
                      Should I take this to mean that the updated drivers for the Xbox One S controller in Bluetooth mode are also expected to come in 4.1?
                      One more thing: I noticed that using an Xbox One S controller (this one) via USB locks up my recalbox 4.0 running on rpi3. Is this known?
                      • LoadedWeapon
                        LoadedWeapon last edited by
                        I also have 2 PowerA mini Xbox one usb controllers.. One Black and one skylander blue... The black one works perfect.. the blue one shows up in the list but no matter what buttons i hold or push it will not configure the controller..
                        Model: 1429930-01
                        Thanks for all the amazing work and maybe a fix for this 🙂
                          acris @rockaddicted last edited by
                          @rockaddicted said in Xbox One Controller Not Working:
                          101.0k
