    Cropping issues with NES games
    Emulator Arcade/PC/Console
    cropping nes
    5589
    • SuperCool
      SuperCool last edited by
      Hi everyone. I am new to Recalbox and this forum...I tried to search on this problem but couldn't find a specific answer.
      I am running Recalbox on a Raspberry Pi 3. Everything is running on default "out of the box" settings right now. Everything is working pretty well, but NES games are cropped on the sides. It's obvious, because words like "Score" or "Player" on the upper left of the screen are partially cut off. I cannot figure out how to fix this problem. Any solutions to this?
      • 8bit_astronaut
        8bit_astronaut last edited by
        I always set smooth games and upscaling games, and that problem is solved
        SuperCool 1 Reply Last reply Reply Quote 0
        • SuperCool
          SuperCool @8bit_astronaut last edited by
          @8bit_astronaut said in Cropping issues with NES games:
          Sorry to be a newb, but what "upscaling" settings are you referring to? In Recalbox or Retroarch? I already have "smooth games" on.
            Yup, this has been reported on a github issue : there is a video crop parameter for retroarch that you can disable to get the full picture. I don't have the link right now but may look for it if you can't find it by yourself
            • SuperCool
              SuperCool @Substring last edited by
              @Substring said in Cropping issues with NES games:
              OK. I think I found it...I guess I'm not exactly sure how to access that? Would I have to remove SD card from the Raspberry Pi and then edit the config on my PC?
                Substring @SuperCool last edited by
                @SuperCool nope, just edit the file with a unix compatible editor (notepad++, notepad2 ... Many others) through a network share
                  The issue i mentionned : https://github.com/recalbox/recalbox-os/issues/1088
                  You'd just need to add it to your retroarchcustomconfig.cfg in \\recalbox\share\system\configs\retroarch\
                  • SuperCool
                    Unix? Oh man, this has quickly gone over my head!
                      @SuperCool or just edit with winscp, that's very easy. We made tutorials explaining how to use it and configure it.
                      Or i could simply give you a 1-line command 🙂
                      • Shuu
                        Shuu last edited by Shuu
                        I confirm that it works (RPI3 + recalbox 4)
                        Using windows 10, edit with notepad++ config file: \\recalbox\share\system\configs\retroarch\retroarchcustom.cfg
                        Adding a new line (just under the line : video_aspect_ratio_auto = true )
                        video_crop_overscan = false
                        Castlevania screen is complete, you will see the S P and E at the upper right side.
                        et Voila ! 😄
