    Updateserver down again or needs reboot?
    updateserver down needs reboot
    • meistadieb
      meistadieb last edited by
      Hi,
      I am currently on recalbox recalbox 3.3.0.-beta17 and I am trying to update to 4.0.0. If I try to update through the gui I only get the information that the update failed and the system will reboot. If I directly execute the rsync-update.sh I get the following message:
      rsync: failed to connect to recalbox.com (151.80.41.198): Connection refused (111)
      rsync error: error in socket IO (code 10) at clientserver.c(128) [Receiver=3.1.1].
      Other users had the same problem and it was solved by rebooting the update server. Could this be done please?
      Thank you!
      Greetings
        voljega Banned @meistadieb last edited by
        @meistadieb no other users didn't have the same problem, it's simply not possible to update from 3.3 to 4.0, you have to reinstall from scratch
        meistadieb 1 Reply Last reply Reply Quote 0
        • meistadieb
          meistadieb @voljega last edited by
          @voljega Thank you. Much appreciated! The error message could be a little bit more userfriendly 😄
            we don't support anymore 3.x branch, there was no need to maintain a server just for that
