    Hard drive
    Your discoveries
    hard
    • recalrod
      recalrod last edited by
      Hello Which hard drive to choose for recalbox v4 and rpi 3 otherwise what are the dd compatible with all that. I have been looking for a solution for months without result. Umpossible to launch the least games with the dd my book studio 3,5 2to Thanks to all and good year 2017
      • supernature2k
        supernature2k last edited by
        Hi,
        I am using a USB 2.5 SATA enclosure with a 320Go DD and I have no problem (no external power source, just USB).
        • azvarel
          azvarel last edited by
          Hi,
          I'm using a USB 2.5 SATA WD Elements with a 1To DD, no external power source
          Zodian Theme | #SNESProject
            Hi !
            any hard drive will do as long as :
            • it works
            • it's correctly formatted (we do recommend fat23 for now)
            • one way or another, it has enough power supplied (from the pi, a self powered hub, or anything else)
