    Juyao Dual Arcade
    Controles / GPIO / Codificador USB
    juyao dual arcade
    3598
    • ferramenta
      ferramenta last edited by
      Olá!
      Comprei uma placa usb modelo Juyao Dual Arcade. O recalbox não reconhece os comandos e os botões. Estava vendo alguns artigos na internet sobre algo como adicionar umas regras para que funcione no recalbox. Alguém pode ajudar pois não entendo nada de programação. Obrigado.
        Substring @ferramenta last edited by
        @ferramenta the juyao just needs usbquirks like the xinmo
        ferramenta 1 Reply Last reply Reply Quote 0
        • ferramenta
          ferramenta @Substring last edited by
          @Substring desculpe a falta de conhecimento mas como realizo o processo de usbquirks no recalbox? Obrigado
            hello
            need information :
            https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
              @ferramenta i don't speak portuguese 😕
              • ferramenta
                ferramenta @acris last edited by
                @acris Sorry for my poor English.
                Here is the link to the file you requested http://dl.free.fr/jg1xMlxqt
                • ferramenta
                  @Substring
                  I also do not speak English but I will try with the translator's help.
                  I sent the link with the file extracted from the recalbox.
                  I found an information on net to add the following statement in the /boot/cmdline.txt path
                  Usbhid.quirks = 0x0314: 0x0328: 0x040
                    @ferramenta you don't have a juyao, it's something different, so it would rather look like usbhid.quirks=0x0810:0x0001:0x040
                    • ferramenta
                      @Substring I was able to get the recalbox to recognize the usb encoder, but I can not properly configure the two players.
                      I configure correctly in emulationstation but when I enter the games configuration gets lost. One is configured correctly but the other is left with the configuration changed.
                        @ferramenta configure player 1 only, and force player 1 only too
