    Emulator aspect ratio resetting
    Emulator Arcade/PC/Console
    • Turnspit
      Turnspit last edited by Turnspit
      Hello everyone!
      I'v got the problem that the ingame aspect ratio resets under certain circumstances.
      I've got a 16:10 screen and thus set the global emulator aspect ratio in the Recalbox configuration via the web browser to a fixed global 16/10. ( global.ratio=16/10 )
      But as soon as I enter the game configuration tab from inside Recalbox, this setting resets ( global.ratio= ) and I'm back to 4:3.
      Is this a known issue or any way to work around, other than not going into that config tab inside Recalbox?
      Cheers!
      EDIT: I'm running the actual version 4.0.0 on a Pi3.
        Substring @Turnspit last edited by
        @Turnspit Hi !
        Not sure 16:10 is a supported ratio, maybe rather 16/10 (french way of writing it ...) Anyway you can set it from ES menus
