    mame2010
    Emulator Arcade/PC/Console
    mame2010
    6
    15
    7954
    • VintagePlay2016
      VintagePlay2016 last edited by
      hi, is there a way that i can use mame2010 core on recalbox? i need it so i can play pigskin, because this game doesnt work on mame2003 or imame4all. but i do know it works on mame2010. thanx for any help on this matter.
        Hi
        This core has nnot yet been included in recalbox. Maybe in 4.1, who knows
        • VintagePlay2016
          i see, i was asking this because i saw this video. thanx
          mame2010 recalbox
            Substring @VintagePlay2016 last edited by
            @VintagePlay2016 we don't ship it yet. Doesn't mean it can't run if you know how to hack recalbox 🙂
            VintagePlay2016 1 Reply Last reply Reply Quote 0
            • VintagePlay2016
              VintagePlay2016 @Substring last edited by
              @Substring sadly i dont, ill have to wait for the new update.
              • metahacker
                metahacker last edited by
                @vintageplay2016 just copy mame2010_libretro.so into /usr/lib/libretro/
                and then you can either change the mame version in the recalbox.conf to mame2010 instead of mame078, or you can go into specific games and hit the SELECT button then EDIT THIS GAME...> and change the core there.
                Alexander Tolstykh 1 Reply Last reply Reply Quote 1
                • Alexander Tolstykh
                  Alexander Tolstykh @metahacker last edited by
                  @metahacker where i can find mame2010_libretro.so? Im already search everywhere.
                  gkralicek2 1 Reply Last reply Reply Quote 0
                  • gkralicek2
                    gkralicek2 @Alexander Tolstykh last edited by
                    @alexander-tolstykh here : https://buildbot.libretro.com/nightly/linux/armhf/latest/
                      Alexander Tolstykh @gkralicek2 last edited by
                      @gkralicek2 I put it in right folder, but its not working for me.
                      gkralicek2 metahacker 2 Replies Last reply Reply Quote 0
                      • gkralicek2
                        gkralicek2 @Alexander Tolstykh last edited by gkralicek2
                        @alexander-tolstykh What do you mean it's not working ?
                        After you placed the file mame2010_libretro.so (contained in the ZIP) in the /usr/lib/libretro folder, what did you do ?
                        The core needs to be declared in the system to be usable. If you don't want to bother modifying conf files, the best and simplest way to achieve integration of mame 2010 is to replace imame4all with it (imame4all is of very little use compared to mame 2003 (aka 078) at least regarding games supported) .
                        In the folder usr/lib/libretro, spot the file named imame4all_libretro.so and rename it to imame4all_libretro.bak, then rename your file mame2010_libretro.so into imame4all_libretro.so and you're done !
                        When you need to execute a specific game using mame2010, select it in the list, then hit SELECT button and "EDIT THIS GAME" option and in the drop-down list of libretro cores for mame select mame4all. Save your modifications and .... Voilà :=)
                        Petroutsos 1 Reply Last reply Reply Quote 2
                        • metahacker
                          metahacker @Alexander Tolstykh last edited by metahacker
                          @alexander-tolstykh did you go to a specific ROM on the gamelist screen and hit COIN (aka SELECT) button, and then edit "metadata" and change the core settings to LIBRETRO/MAME2010?
                          its working fine for me this way...now i can play TAPPER 🙂
                          however, my P2 joystick input is ignored....not sure the solution yet...
                          • metahacker
                            i take that back.....the P2 input problem seems to be limited to the Xenophobe ROM...all input seems to work fine for other games (like Altered Beast)
                            • Petroutsos
                              Petroutsos @gkralicek2 last edited by
                              @gkralicek2 Hi, thanks for this reply, but I would like to know which configuration file to modify to add the mame2010 core to the list of cores without having to replace it with imame4all. It's possible?? I have added the file mame2010_libretro.so to the folder /usr/lib/libretro but it does not appear in the list of cores ...
                              Thanks in advance...
                                Substring @Petroutsos last edited by
                                @petroutsos just be a little patient, it's ready on our side
                                Petroutsos 1 Reply Last reply Reply Quote 0
                                • Petroutsos
                                  Petroutsos @Substring last edited by
                                  @substring Of course, thank you...
