    Hotkey not working in N64 emulation
    GamePad/GPIO/USB encoder
    hotkey
    5385
    • Ares2502
      Ares2502 last edited by
      Hello everyone,
      I am using recalbox since this day and so far am really loving it on my RP3.b.
      As my BT Dongle (Delock Bluetooth 4.0 USB Adapter) is still on its way, I am using my 8bitdo NES Pro controller connected to USB. I configured the Hotkey to be L3.
      Everything seems to be working really good, but the Hotkey seems not be recognized when running the N64 emulation. This really sucks, as the only way to go back to the recalbox main menu is cutting the power of the Rasperry Pi.
      I would really appreciate any advice, what I should change to get the thing working.
      Another question that arose is, if it is possible to select the shader to be used in the Archretro menu (I really hate click through all 60 available shaders...).
      Thanks for your help!
      Merry Christmas and happy Retro Gaming!
        Substring @Ares2502 last edited by
        @Ares2502 hi !
        I have no problem with the hotkey in N64. Is your pad the only one ? No.other is plugged ? We never set hotkeys for olayers ither than the first one
        Ares2502 1 Reply Last reply Reply Quote 0
        • Ares2502
          Ares2502 @Substring last edited by
          @Substring
          Thanks for answering.
          Yes, the Controller is the only gamepad connected at the moment.
            @Ares2502 need to see your ~/configs/mupen/mypen64config.ini, something like that
            • Ares2502
              Could you explain me how to get this information after I connected to recalbox using putty?
              0_1482664586212_upload-17521c01-406a-47c3-bd3d-1fb54cebcb3f
              • Ares2502
                Found it. There is no such file in that directory.
                0_1482664899936_upload-1fa0880f-db17-4839-b89e-101b56e67bdc
                  @Ares2502 i said "something like that" because i don't quite remember the name of the file. But it's for sure in ~/configs/mupen or ~/configs/mupen64
                  • Ares2502
                    Ares2502 last edited by Ares2502
                    Hmm... There is no directory ~/configs/mupen. And in the mupen64 is no files like this (See screenshot above).
                    Found this:
                    0_1482670915999_upload-bf47c8fd-ee1e-4b92-b6fd-7d1ad67dc209
                    in recalbox/system/configs/mupen64
                    Is there the file you need?
                    • Ares2502
                      This is the InputAutoCfg.ini
                      [Bluetooth Wireless Controller ]
                      plugged = True
                      plugin = 2
                      AnalogDeadzone = 4096,4096
                      AnalogPeak = 32768,32768
                      Mempak switch =
                      Rumblepak switch =
                      mouse = False
                      A Button = button(1)
                      B Button = button(4)
                      C Button D = axis(3+)
                      C Button L = axis(2-)
                      C Button R = button(0) axis(2+)
                      C Button U = axis(3-) button(3)
                      DPad D = hat(0 Down)
                      DPad L = hat(0 Left)
                      DPad R = hat(0 Right)
                      DPad U = hat(0 Up)
                      L Trig = button(6)
                      R Trig = button(7)
                      Start = button(11)
                      X Axis = axis(0-,0+)
                      Y Axis = axis(1-,1+)
                      Z Trig = button(8)
                      Other files in the directory would be:
                      0_1483460424568_upload-13645fcc-93f9-4db8-a92b-9876d1bba51d
                      Any help would be great... What I tried was renaming the CFG to *.bak to see if a new created one would solve the issue. (Without success).
                      Btw: The controller settings seem to be messed up quite a bit... Left on the left analog stick is not working neither....
                      Other emulators are still running great.
                      • reroshaggy
                        reroshaggy last edited by
                        My response I'm sorry won't be helpful, I'm hoping you may have stumbled across the answer.. I deleted my n64 setup after dealing with this problem for a while. Even after I edited the config with root access and terminal, the config always reverted to its defaults. I hope someone helps us.
