    WiFi Config issues
    wifi config
    • BubbleBoy
      BubbleBoy last edited by
      Hi all
      Cannot seem to connect to my WiFi.
      In the beginning: The status and IP are both NOT CONNECTED.
      So I then add in my SSID and WiFi Key and enable WiFi.
      Then I get a config error and the IP addres is now:
      fe80::ba27:ebff:....... and a few other letters, numbers and colons.
      Any suggestions please?
      rapid 1 Reply Last reply Reply Quote 0
      • rapid
        rapid @BubbleBoy last edited by rapid
        @BubbleBoy Try disable dhcp-v6-server in your router. For me this worked after I disabled it in my fritzbox. Now I have an ipv4 adress.
        Now I can ssh into my device.
        BUT unfortunatly there is a bug in the version 4.0.0 that don't let me connect to the internet. Hope it will be fixed soon. You can find that bug in the forum.
        https://forum.recalbox.com/topic/5039/can-t-connect/1
