    Adafruit i2s audio
    GamePad/GPIO/USB encoder
    adafruit i2s audio
    3707
    • pati
      pati last edited by
      Hey Guys,
      is it possible to use i2s audio? I've tried with adafruit installation guide but it didn't work.
      Any suggestions?
      https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp/overview
        Substring @pati last edited by
        @pati hi
        The setup looks very easy. Which step are you failing on ?
        pati 1 Reply Last reply Reply Quote 0
        • pati
          pati @Substring last edited by
          @Substring no sound :-).
          I just remembered that this may be an overlap with the GPIO controller module (mk_arcade_joystick_rpi). The GPIO for "Y" is used by the i2s module for "BCLK". I will try to adjust the pin assignment of the joystick.
            @pati just disable the GPIO joystick, you can't remap yet the gpio pins
            • pati
              @Substring hmm. I can try it for test purposes, but I still need gpio-controllers (pins already soldered). No chance to switch gpio-pins? I wanna use this audio module in a gameboy 🙂
                @pati the gpio driver was updated a little while ago and will support gpio pin configuration in 4.1. Unless you want to recompile it by yourself 😉
                • pati
                  pati @Substring last edited by pati
                  @Substring that's sounds good. I'll try to disable joystick first. Thanks for your support 🙂
                    @pati disable it time to test your device, at least 🙂
