    How to turn off subtitles in Kodi?
    MediaCenter & Dualboot
    turn subtitles kodi
    • emblemparade
      emblemparade last edited by
      Actually, I also want to change audio language, change subtitle language, etc.
      There should be a context menu during movie play, but I cannot access it using a game controller. 😞 I tried every combination I could think of!
      Am I missing something obvious?
      • Lefti Right
        Lefti Right last edited by
        I am also facing this Problem, i cant find the context menu for changes like aspect Radio, Sound, etc... Is there some hidden button Combo?
        • cissou
          cissou last edited by
          On a keyboard,
          T turn on/off subtitle,
          L switch next subtitle,
          M show the menu,
          I can't remember if those key are mapped on the pad
          you have to check the file : recalbox/share/system/.kodi/userdata/keymaps/remote.xml
          and
          recalbox/share/system/.kodi/userdata/Lircmap.xml
          and configure with : http://kodi.wiki/view/keymap
          You can also use the android app kore on you smartphone
          Dell 3020M + X360 sans fil
          Bartop Modulaire : Rpi3
