    How to fix incorrect game metadata.
    fix incorrect metadata
    • Christopher 'Dange' Hornak
      Christopher 'Dange' Hornak last edited by
      I had the scraper run with "user decides on conflics" it got some of the games wrong. How do I fix them? I can see I can edit the data but I don't want to have to manually type in all the correct information.
        Rescrape ?
        Christopher 'Dange' Hornak 1 Reply Last reply Reply Quote 0
          Christopher 'Dange' Hornak @Substring last edited by
          @Substring yeah but how do I have it just rescrape the incorrect ones? When I goto "edit this games metadata" by pressing select on the game It allows me to manually edit the data. It also has "input" as an option. When I change the title and hit search nothing happens.
            I figured it out. My scraper was set to MAMEDB instead of THEGAMESDB. Switched it back and I'm able to rescrape each game individually.
              Substring @Christopher 'Dange' Hornak last edited by
              @Christopher-'Dange'-Hornak just forgive TGDB terrific speed 😕
