    Compatible adapters for wireless xbox 360 controller
    adapters wireless xbox 360
    2866
    • eb2016
      eb2016 last edited by
      Hey everyone. If I understand correctly, you need to get a adapter in order to run a wires XBOX 360 controller?
      Just wondering if anyone knows of any good compatible ones? I could find any mentioned on the wiki and I want to make sure I get one that works.
      Thanks
        voljega Banned @eb2016 last edited by
        @eb2016 just get the official microsoft one or any other one on Amazon really
        eb2016 1 Reply Last reply Reply Quote 0
          Or check the recalstore, there is a clone one that has been successfully tested
          • eb2016
            eb2016 @voljega last edited by
            @voljega I had a look at the official microsoft one but it's 4 times more expensive than the third party ones.
            Unfortunately I bought a bluetooth USB adapter as I thought the controller would work with that. I was wrong...
            • eb2016
              eb2016 @Substring last edited by
              @Substring said in Compatible adapters for wireless xbox 360 controller:
              I had a look at the store but they're not shipping to my country unfortunately.
                Substring @eb2016 last edited by
                @eb2016 at least you have the reference of the device can can look closer to you
                • eb2016
                  @Substring yeah I''m going to hit up ebay and see if I can find a supplier
