    Solved recover mame tab key for mame menu
    Emulator Arcade/PC/Console
    mame
    • thanosazlin
      thanosazlin last edited by
      i was messing around with the tab/menu for mame, some how i put my R button on my controller as well as Tab that both were opening the tab/menu for mame. i pressed enter on the key for tab in the mame menu and hit escape twice to clear it like i have done with other mappings.
      now i have locked myself out of the mame menu 😞 as tab wont' even bring it up? is there a cfg file somewhere for mame that i can ssh in and fix to get this working again?
        That happened to me too, but never found which file does it ... Try deleting ~/configs/retroarch/retroarchcustom.cfg. But it might as well be elsewhere
        • iggy2
          iggy2 last edited by
          I have the same problem, any solution??
          Best regards
          Magnus
            Il faut supprimer /recalbox/roms/mame/mame2003/cfg/default.cfg puis rebooter. Ce fichier est accessible par réseau dans \\recalbox\share\roms\mame\mame2003\cfg\
            nacho73 1 Reply Last reply Reply Quote 1
            • nacho73
              nacho73 @Substring last edited by
              @substring
              You´ve saved my life! I had changed/erased the start key in Mame and I couldnt play any game. Buf!!! Thanks to you, sir, that´s history!
              Thanks a lot!! I owe you a beer!
