    Solved extend file system
    extend file
    5767
    • Bowzer Mike
      Bowzer Mike last edited by
      Cant seem to extend file system on my SD card, Any help would be great. Im pretty sure I am formatting it and writing the image properly.
        which filesystem are you talking about ? There are 3 of them
        Bowzer Mike 1 Reply Last reply Reply Quote 0
        • Bowzer Mike
          Bowzer Mike @Substring last edited by
          @Substring im trying to upgrade from a 16 gig to a 32 gig SD card but when I do I don't get all the space in the 32 gig card
            Substring @Bowzer Mike last edited by
            @Bowzer-Mike if you made an img of your 16GB, of course it won't resize to 32GB ! It's a binary image, what did you expect ? You need some linux software to be able to extend the 3rd partition to fit all the free space
            Bowzer Mike 2 Replies Last reply Reply Quote 0
            • Bowzer Mike
              @Substring Dont have linux so dont know what to do,. Lots of stuff I read made it seems like its a simple thing to do and could just use a program like mini tool partition wizard
              • Bowzer Mike
                @Substring Could I do a new setup on my new SD card and copy the roms and bios over my network and re add them manually to the new cards setup over my network
                  @Bowzer-Mike of course you can
                  • Bowzer Mike
                    @Substring Took a couple hours but it worked! Managed to upgrade without any special programs
                    • issame
                      issame last edited by
                      @bowzer-mike can you explain how?
                      thanks
