    Solved All Roms crash / don't load and return me to console
    roms crash dont return console
    4362
    • jasonb
      jasonb last edited by
      Roms crash and return to the console screen.
      I am using a raspberry pi 3 b. I have the recalbox 3 os loaded with recalbox v4 loaded. HDMI to 1920x1080 screen. n64 ROMS will load correctly.
      Is there a way to reset my recalbox os to the factory defaults without wiping the card? I have another os installed on the card.
      I am thinking I should just get another sd card specifically for the recalbox os...
      Any help from the recalbox community would be greatly appreciated.
      Thanks!
      • 8bit_astronaut
        8bit_astronaut last edited by
        Well, i have this problemas once, the sd or pendrive is corrupted, maybe because you power off the console wrong.
        The solución....you had to format and reinstall.
        Sabe your games, saves, and bios, and reinstall
        jasonb 1 Reply Last reply Reply Quote 1
          Substring @jasonb last edited by
          @jasonb i don't understand anything to your recalboxOS version 😮
          • jasonb
            jasonb @Substring last edited by
            @Substring
            When i uploaded the recalbox onto the sd card I had to choose the recalbox os for the raspberry pi model.
            I chose "recalboxOS-rpi3" for the installation because I have the raspberry pi rev3 b board.
            • jasonb
              jasonb @8bit_astronaut last edited by
              @8bit_astronaut
              Thanks for the advice. I was kinda thinking this was the issue.
              Did some of the ROMS work and some didnt??
              • jasonb
                I just reset my pi and now all of the roms are working again.
                Thanks for the advice, I wish the card wasn't corrupted and that I used another card for recalbox only.
                ¯_(ツ)_/¯
                  You never should hve chosen your pi version ... This is supposed to be autodetected
