    Solved No Neogeo in Raspi Zero
    Emulator Arcade/PC/Console
    neogeo raspi zero
    • tomas_em
      tomas_em last edited by
      Any possibility to get Neogeo with fba2x core working in Raspi Zero? CPS1 and CPS2 works OK.
        Hi !
        On pi0, the default emulator is pifba. You can switch yourself to the fbaalpha if you prefer, but don't expect great performances.
        And I may be wrong, but pifba/fba2x hasn't been updated in a while
        • tomas_em
          Hi,
          yes, I know, that on pi0 is the default emulator pifba. And it works great for all CPS1/CPS2 which has similar hardware. Do you know if pifba ever supported Neogeo?
          • tomas_em
            Solved!! Problem was in the BIOS file, I downloaded another one and now Neogeo works!
