    Wired xbox 360 controller connection problems
    Controller/GPIO/USB
    wired xbox 360 connection
    3252
    • thunder
      thunder last edited by
      Hi
      I'm having problems with the connection of a wired xbox 360 controller.
      I've already edited the recalbox.conf file
      controllers.ps3.enabled=0
      controllers.xboxdrv.enabled=1
      But after closing the window and rebooting the RP nothing happens and the changes in the file aren't saved.
      Help Me!!!!!
        Substring @thunder last edited by
        @thunder hi
        Please edit the file through http://recalbox/ if you are on windows. If you have a mac or linux, it's http://recalbox.local
        • thunder
          @Substring i need more accurate infos. Can you explain this step by step?
          Thank you so much
            @thunder Edit the recalbox.conf file, set controllers.gpio.enabled to 0 and reboot
            • thunder
              @Substring i have resolved by using a fake ps3 controller.....but i have other problems: when i start a game the controller doesn't work (it happens often, and i think it depends by the game i play) and sometimes the keyboard too seems not working. How can i fix?
                Seeing the problems you've had So far, i really sonder what's wrong un your setup
