    Error filesystems mounting
    • Allan Brown
      Allan Brown last edited by
      Hi
      I have a raspberry pi 3 with a 128gb memory card. When I try to install recalbox I get:
      rPI-3 error file systems mounting.
      I have set the downloaded the image multiple times and the format is set to fat32 and primary.
      Any help most gratefully received!
        Hi
        could you explain at which moment you get that error ? What is your SD brand ? have you checked it's compatibility ?
        • Allan Brown
          This happens at 100% on the initial installation.
          This is the memory card I have:
          https://www.amazon.co.uk/Memory-CAMERA-SAMSUNG-GALAXY-MOBILE/dp/B00SC8QF56/ref=sr_1_4?ie=UTF8&qid=1477594527&sr=8-4&keywords=micro+sd+128
            Substring @Allan Brown last edited by
            @Allan-Brown "at which moment" means "please describe the whole procedure and what you see on the screen until it hangs" 🙂
            Samsung memory cards are not said to be very compatible with NOOBS ...
            101.4k
